1 - 1 of 1 Posts
I have the defrost only problem.
The temp actuator works.
There are no vacuum leaks, my hubs lock and I've done all the checks on the parts under the hood.
The actuator under the dash with the j hook coming off the bottom does not move no matter.what position the climate controller is in.
If i move it manually, I get AC blowing out the floor vents, but never the dash vents.
My question, before I replace this part; is there another vent door actuator that controls the dash vents, or is this the only one?
When I replace this part, will I be able to select dash vents again, or be stuck with defrost ir floor vents?
775839
Thanks in advance.
1 - 1 of 1 Posts
