Hey new to this site. Joined because I'm in need of your guys help!!!!!!! I have an 01 f-550 with the 7.3l. 237k on the clock. 6 speed manual. The truck is a car carrier. Pcm crapped out a couple months ago, changed cps at th at time(gray from Napa). Reman pcm and truck fired right up. Used truck a few times with no issues. Problem occurred while driving home on the highway one day and the truck dropped some cylinders. Idk how many. Could barely pull 15mph. Limped up the shoulder for a couple miles and finally reached the top of incline and rolled down and truck seemed to clear out. Made it to a buddy's shop and pulled driver valve cover. Connection seemed OK...contact cleaned and dielectric greased large plug harness(42pin??), and the uvch in and out. Drove home with no issues.. did one more tow about 30 miles or so no issues. Last time I used the truck miss fire and no power occurred after 10-15 miles of driving. Soooo I changed uvch and gasket on both sides with OEM parts and 50 cent trick. Problem still exists. Truck will start and idle fine. But as soon as it reaches operating temperature it starts missfiring and blowing white smoke, maybe kinda gray. Idles horribly no power, miss fire and white smoke and hard to rev past 2000..... if I turn the truck off and let it sit for a while the truck will start fine and idle till i start driving and get to operating temp. Hardly any blow by at idle. Fuel pressure is at 65 PS I at idle and under rev while its running good haven't checked it at WOT under load yet didn't know. No cel when problem begins. Passed buzz test while cold no dtcs. Sounded good and even. Next idle and warm up to operating temp. Cct passed. No codes. Next koer self test and I get p0476. Idk. What's going on. Can anyone point me in some kind of direction. So frustrated. Oil change rotella and motor craft filter less than 500 miles. Same with fuel filter. Drained bowl and fuel seems to look OK.....PLease help. I can try answer anything relevant to the best of my knowledge..thanks in advance!!!!!! Will try post a did of how it is when running bad. Sorry video!!
