Busted a rear brake line , but also needed to swap rear end out . So I waited to fix line system drained out . Well got line fixed filled with fluid left bleeders open until fluid came out . Closed system back up bled brakes out until no air . Now when it’s running first brake pump goes to the floor I changed master cylinder also . Thanks in advance for any help
You still have air in the lines or you have a defective Master
Did you pre-bleed master before installing? How did you bleed lines? Power bleeder or manual? if manual, tell me how you did it.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
