How to fit 2016+ wheel hub covers on my 2008? - Ford Powerstroke Diesel Forum
Forum sponsored by: discounttire.com
 2Likes
post #1 of 11 Old 07-12-2019, 11:17 AM Thread Starter
Quoted: 63 Post(s)
I have an 08 with stock wheels and 275/70/R18 tires that will need replaced by next year probably. I'm finding alot of 2016+ F-250 and 350 18" and 20" wheel/tire combos for sale for $400-$600. They have very few miles on them. So I figured I would just buy a set of those stock take-offs since it would be cheaper than new tires, and I would get some nicer wheels as a plus. I want to stay similar to oem size since I tow alot and want to keep good mpg. They are all 8 x170mm lug pattern so I should be good to go there.
My question is, they have a lot of different styles of wheel hub covers. The rears shouldn't be a problem, but do the newer ford hub covers fit our older 08 style hubs? I attached pics of what type of hubs I have. I attached a couple of examples that show the different type of hub covers. Or do you just not run any hub/lug nut covers? Just want to make sure they would bolt right up to my 08 fine. Thanks!
https://classifieds.ksl.com/listing/56587503
https://classifieds.ksl.com/listing/56764818
https://www.facebook.com/marketplace...5908183804754/
ID:	720789   Click image for larger version
onecrazyfoo4u is offline
post #2 of 11 Old 07-12-2019, 01:02 PM
ZMANN's Avatar
Quoted: 3897 Post(s)
hubs are the same 05 up
image from your link
looks like cap fits ?
HeavyAssault likes this.
6.0 flush pdf
ZMANN is offline
post #3 of 11 Old 07-12-2019, 01:23 PM Thread Starter
Quoted: 63 Post(s)
Yeah they look like they would fit. And the back hub caps would just mimic the look of the real front hubs with the opening in hub caps. I was just wondering if anybody had tried them out on a 6.4l generation truck to make sure they do fit.
post #4 of 11 Old 07-12-2019, 09:01 PM
Quoted: 681 Post(s)
I think you need to use the newer ('17+),closed end, lug nuts for those caps. I think
ZMANN likes this.
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
post #5 of 11 Old 07-13-2019, 06:52 AM
ZMANN's Avatar
ahh i did not notice the new caps did not cover the lugs
looks like gorrila locks would fit perfect
6.0 flush pdf
ZMANN is offline
post #6 of 11 Old 07-13-2019, 06:59 AM
ZMANN's Avatar
or on second /third glance lol
i see a spring looking deal in each lug opening I wonder if thats how they are retained ?? ( a grove in the OEM lug )
6.0 flush pdf
ZMANN is offline
post #7 of 11 Old 07-14-2019, 09:47 PM
Quoted: 681 Post(s)
You are correct
-Michelangelo
kaya is offline
post #8 of 11 Old 07-15-2019, 05:40 AM Thread Starter
Quoted: 63 Post(s)
Oh, so if I buy a set, make sure to get the oem lugnuts from the seller too? Most of them come with lug nuts...which I'm guessing are the same thread/pitch as my 08? But that's just for 2017 and above? That's crazy...haven't seen/owned any vehicles where the lugnuts hold the hub cover on.
post #9 of 11 Old 07-16-2019, 12:56 PM Thread Starter
Quoted: 63 Post(s)
May be a dumb question, but will the 275/65/R20 wheels/tires fit on my truck without any rubbing? Going from 275/70/R18, it will increase diameter by 1", with the same width. I imagine it would fit no problem but just wanted to check.
post #10 of 11 Old 07-16-2019, 08:04 PM
Quoted: 681 Post(s)
That is a stock 08 tire size for 20"
You'll be ok
-Michelangelo
kaya is offline
