Lift and wheels - Ford Powerstroke Diesel Forum
Forum sponsored by: discounttire.com
 2Likes
post #1 of 21 Old 06-29-2019, 04:04 PM Thread Starter
Quoted: 3 Post(s)
What size lift can I put on my truck to clear 22x14 with 35in tires I have a 03 f350 7.3
Tristan Bennett is offline
post #2 of 21 Old 06-29-2019, 04:55 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 779 Post(s)
Feedback Score: 3 reviews
How much money can you spend?
Heavy_GD likes this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 21 Old 06-29-2019, 06:01 PM Thread Starter
Quoted: 3 Post(s)
I don’t wanna go to big in the lift cause I still use it for work
post #4 of 21 Old 06-29-2019, 08:14 PM
Fire From the Clouds!
Horizon122's Avatar
Quoted: 219 Post(s)
You're going to need a 6" lift with no/very minor trimming or a 4" lift with fender trimming. You're also going to want to go with a 35x15.5 (375/45r22) so your tire doesn't blow off the bead when you put a pallet of bricks in the bed.
Since you use the truck for work i'd build a kit with a mix of parts to retain load capacity while keeping superior ride. I'd do a 6" front BDS lift mixed with parts from PMF to beef up the front and obtain the rear lift. Parts from PMF include, track bar, dual steering stabilizer, sway bar links, rear traction block with stage 2 traction bars, adjustable ubolt plates and ubolts.
You're also going to want to put in new balljoints, tie rod ends, red head steering box, to start. Really the only way to gaurentee your truck won't go all over the road and your steering wheel will remain centered under all conditions.
Don't cheap out otherwise you'll most likely end up on the side of the road with a broken truck.
22x14's are a lot to ask for on these trucks and require a lot of money to avoid problems.
Also for wheels our trucks use a 125 hub bore. The newer trucks use the 130. When looking at wheels they will say 8x170 125 or 130 hub bore. Make sure to get a 125 otherwise there will be a gap when mounting to the axle.
HeavyAssault likes this.
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 PMF lift on 325/60r20 Nitto M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
post #5 of 21 Old 07-01-2019, 07:22 PM Thread Starter
Quoted: 3 Post(s)
I have a long wheel base what would be the best traction bars to get?
post #6 of 21 Old 07-02-2019, 07:27 AM
Horizon122's Avatar
Quoted: 219 Post(s)
1999-16 Ford F-250/350 PMF Single Traction Bar Kit
post #7 of 21 Old 07-02-2019, 07:41 AM
00t444e's Avatar
Quoted: 550 Post(s)
35s on 22" rims, You trying to look like your from the Hood or what? A tire with a skinny sidewall like that serves no purpose on a pickup truck.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #8 of 21 Old 07-02-2019, 08:51 AM
Bri_Man57's Avatar
Quoted: 154 Post(s)
6" lift for 35s? That is way overkill, you need a 2.5" lift to run 35s, not sure if the big rim size is playing into thay recommendation.
Sent from my SM-G900V using Tapatalk
Bri_Man57 is offline
post #9 of 21 Old 07-02-2019, 09:12 AM
Heavy_GD's Avatar
Quoted: 3107 Post(s)
Garage
Feedback Score: 4 reviews
14 wide is hard to clear.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #10 of 21 Old 07-02-2019, 09:20 AM
Bri_Man57's Avatar
Quoted: 154 Post(s)
Going taller doesn't push them away from the leaf springs though?
