New wheel offset help 2003 F250 - Ford Powerstroke Diesel Forum
Wheels, Tires, and Brakes Here's where you can post all your topics and questions about wheels, tires and brakes. Forum sponsored by: discounttire.com
 2Likes
  • 1 Post By Discount Tire
  • 1 Post By Horizon122
post #1 of 8 Old 05-17-2019, 06:43 AM Thread Starter
I am currently running 2” spacers on stock 2007 20” F250 KR wheels. I want to stop running spacers and just get some 20” wheels with the correct offset so they sit the same as my current setup. Edge of my tire is about an inch outside the fenders. Im running 35x12.5x20’s. Anyone who can steer me towards the correct offset? Thank you very much.
Eyekahn is offline
post #2 of 8 Old 05-17-2019, 07:17 AM
Heavy_GD's Avatar
Quoted: 3152 Post(s)
Garage
Feedback Score: 4 reviews
@Discount Tire ....
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #3 of 8 Old 05-17-2019, 08:46 AM
Discount Tire's Avatar
Quoted: 35 Post(s)
A 9-inch wide wheel with around 0 to +12mm offset is what you need
Heavy_GD likes this.
Low Prices! More Choices! Trusted Experts!
At The Store:
To Your Door:
Useful Links:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Discount Tire is offline
The Following User Says Thank You to Discount Tire For This Useful Post:
Heavy_GD (05-17-2019)
post #4 of 8 Old 05-17-2019, 05:31 PM
Fire From the Clouds!
Horizon122's Avatar
Quoted: 238 Post(s)
A 0 to +12 offset is going to rub the leaf springs with those tires on full turn. You're going to want a -12 offset on a 9" wide wheel.
voodooridr likes this.
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 PMF lift on 325/60r20 Nitto M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
post #5 of 8 Old 05-18-2019, 08:48 AM
RuthLessDiesel's Avatar
Garage
A -12 9" wide wheel or maybe a 10" wide with -24 if you want a little more poking out than you already have.
Check out Customoffsets and look through their gallery. It helped a lot when picking out wheels for mine
RuthLessDiesel is offline
post #6 of 8 Old 05-18-2019, 10:11 AM
Horizon122's Avatar
Quoted: 238 Post(s)
He doesn't seem to be that tall. A -24 is going to definitely require bumper and fender trimming. Ask me how I know.
post #7 of 8 Old 05-18-2019, 11:06 AM Thread Starter
I am on stock suspension. Slight rub on current setup.
Eyekahn is offline
post #8 of 8 Old 12-07-2019, 12:27 AM
2MANYPROJ3CTS's Avatar
Quoted: 18 Post(s)
Garage
20x9 -12 will keep you off the springs but you may still have to trim the corners of the plastic if they are true 35s. I'm running 18x9 -12 with a 33.6" tire on f350 springs on my Excursion and it's pretty close at the front corners.
Semper Fi
Daddy's truck- '02 F250/7.3/6spd/4x4/6"lift/35's/Procomp traction bars/K&N intake/4" Banks turbo-back/aftermarket turbo/Hydra
Momma's truck- 01 Excursion/7.3/Auto/4x4/AFE stg 2 intake/walker Big Truck Muffler/BD Thruster II turbo/ TS6 /295x70's/F350 springs
2MANYPROJ3CTS is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
wheel offset question... +6 or -18 with 37 inch wheels on 4.5 inch lift powellga 6.7 Exterior Discussion (2011-2016) 1 01-31-2018 10:06 PM
2003 f250 5" backspace? Jonzk 6.0L Exterior Discussion 1 03-06-2017 10:18 PM
Wheel Tire Offset Verification steamprinter 6.0L Exterior Discussion 1 09-05-2016 06:26 AM
