2011 f250 caliper locking up - Ford Powerstroke Diesel Forum
Forum sponsored by: Discount Tire
post #1 of 5 Old 05-05-2019, 08:22 AM Thread Starter
About a year ago my passenger side caliper locked up. Had it replaced with an oem caliper maybe six months after same thing on the driver side. Now the passenger side locked up again yesterday it seemed to happen after a hard stop. Let it sit overnight and is fine now but why would this keep happening? Is there a potential other problem causing the caliper to lock up? Thanks in advanced
Ryan9864 is offline
post #2 of 5 Old 05-05-2019, 08:50 PM
Quoted: 26 Post(s)
Maybe the ABS is contributing to this?
Tom
2014 XLT Premium CC Dually 2WD, Remote Start Added, Diesel Site Dual Filters, Rudy's Cold Air Pipe, Infotainment Radio Swap + Rear Camera Added
2002 XLT CC Dually 2WD, 6 Spd, True Workhorse that kept going.
1999 F250 Lariat CC LB SRW 2 WD, Automatic. Just didn't perform towing.
tomshep is offline
post #3 of 5 Old 05-21-2019, 07:40 PM
I have the same problem on my 03. I've replaced rotors, calipers and pads multiple times. About a year or so ago i replaced ALL of the pads calipers and rotors with Power Stop brand and also bled all the brake fluid, plus i flushed the Power Steering fluid because i read somewhere that it shares the Hydroboost or something. This last month i noticed the brakes seemed to be dragging again and found the (not so old Power Stop) ds rear caliper is seized and smoking. AGAIN!! I don't know whats causing this brake caliper seizing problem but it sure is frustrating. The fronts seem to be fine still, so i just got done replacing the 2 rear brake assembly's again with new pads, rotors, calipers. ($350!) Remarkably, my 03 has had 0 problems, other than the brakes....
c-2-4 is offline
post #4 of 5 Old 05-21-2019, 07:45 PM
Tom, if the ABS was contributing, would/wouldn't there be an ABS warning light? When it works, it's fine. Just every once in awhile it seizes and wears out some pads and ruins a rotor. Usually, if you don't smell or see smoke, it's doesn't get noticed until it's too late..
c-2-4 is offline
post #5 of 5 Old 05-22-2019, 04:32 AM
Heavy_GD's Avatar
Quoted: 3080 Post(s)
Garage
Feedback Score: 3 reviews
A little light reading on the topic.
https://www.powerstroke.org/forum/wh...er-repair.html
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is online now
Similar Threads
Thread Thread Starter Forum Replies Last Post
2011 f250 p1839 4x4 light Blown96w 6.7 Problems Forum (2011-2016) 1 08-14-2018 04:22 AM
Low Fuel Rail Pressure P2291 2011 F250 frei 6.7 Problems Forum (2011-2016) 20 12-02-2016 06:30 PM
2005 F250 KR Rear Caliper Seized Multiple Times zbea1144 6.0 Drivetrain problems 16 11-02-2016 06:15 PM
2011 f250 intermittent power loss/no throttle repsonse Rileyleach 6.7 Motor Problems (2011-2016) 0 07-25-2016 07:23 PM
