Brake pedal goes to floor when turning right - Ford Powerstroke Diesel Forum
Wheels, Tires, and Brakes Here's where you can post all your topics and questions about wheels, tires and brakes. Forum sponsored by: discounttire.com
post #1 of 14 Old 03-25-2018, 06:57 AM Thread Starter
Quoted: 2 Post(s)
I have a 06 F350 dually. For the past week or so my truck has been having a weird issue. Whenever I turn the wheel all the way to the right the brake pedal will go to the floor and it barely brakes and my TBC code will come on. Once I straighten the wheel the brake pedal will feel normal after I pump it once or twice. I have ordered a new master cylinder but I have a feeling it not gonna fix my problem. Has this happened to anyone else. The truck has a 2.5" level kit and 315/70/17 tires
Sent from my SM-G955U using Tapatalk
modular89 is offline
post #2 of 14 Old 03-25-2018, 07:17 AM
Mike Gs's Avatar
Quoted: 103 Post(s)
I would suspect the hydro boost system. Has spool valves and such that can cause wierd things with the pedal.
Mike Gs is offline
post #3 of 14 Old 03-25-2018, 07:41 PM Thread Starter
Quoted: 2 Post(s)
But would that allow the pedal to go all the way to the floor. I would think the pedal should only be able to go so far if the master cylinder hydraulics are good
post #4 of 14 Old 03-25-2018, 09:12 PM
Quoted: 43 Post(s)
Garage
What's your brake fluid level? Have you tried bleeding the calipers?
vitamin joe
2004 Ford F-350 Lariat FX4 4x4 SRW
335249 km (208314 miles) as of Oct 29, 2019
15.13 avg mpg (last 12 months)
Delo ELC - CAT EC-1 . EGR Cooler Deleted . Edge Juice Platinum with Attitude . Blue Spring Upgrade . Sinister Diesel Coolant Filter. AFE Magnum FORCE PRO 5R Stage-2 CAI . Warn Premium Locking Hubs . 2.5 inch Rough Country Leveling Kit . Leece Neville 230 Amp Alternator
vitaminjoe is offline
post #5 of 14 Old 03-26-2018, 07:36 AM
Mike Gs's Avatar
Quoted: 103 Post(s)
Yes it can cause pedal drop.
Mike Gs is offline
post #6 of 14 Old 03-26-2018, 07:58 AM
"RLTW" Tennessee
F250_SUPER_4x4's Avatar
Quoted: 295 Post(s)
Make sure that the brake lines are not kinking, binding or twisting when making a turn
1974 F100 RC 351W/C4
1978 F250 Super Cab 400/C6
2015 F250 PSD CC KR 408/6R140
2017 Harley Ultra Limited 107/6SPD
F250_SUPER_4x4 is offline
post #7 of 14 Old 03-26-2018, 06:52 PM Thread Starter
Quoted: 2 Post(s)
Brake fluid is full and I have never opened up the brake system to allow air in it. I have also checked the hoses when turning. Maybe I will replace the hydroboost with the master cylinder
post #8 of 14 Old 05-28-2019, 06:51 AM
What did you ever find out was problem? I’m having same exact problem now on my 05 250. I have replaced master cylinder, power steering pump, high pressure lines and hydro boost .. 2 mechanics looked at it and are stumped.. please and thank you for help..
Steveluther is offline
post #9 of 14 Old 10-15-2019, 06:33 AM
Quoted: 17 Post(s)
I'm experiencing this same issue, its either direction at lock for me. Scary af. I'll start checking these things today. Unfamiliar with a system like this so I'll be learning. Doing my trans service and was going to my brakes at the same time this weekend.
Oneops is offline
post #10 of 14 Old 10-15-2019, 02:07 PM
Quoted: 17 Post(s)
Power steering fluid is a little bit low and a bit dirty, brake fluid is dirty but full.
Oneops is offline
