37" Toyo MT's with 4" lift - Ford Powerstroke Diesel Forum
Wheels, Tires, and Brakes Here's where you can post all your topics and questions about wheels, tires and brakes. Forum sponsored by: discounttire.com
 3Likes
post #1 of 13 Old 01-16-2018, 07:13 PM Thread Starter
r4dranger's Avatar
Guys I have an 05 F250 with a 4" BDS lift and wanted to see how much cutting I will have to do to make 37" Toyo MT's fit with 20x10 wheels with a -12 offset. Does anyone know if this will work with minimal cutting. I've read there is some cutting on the 99-03 with the same setup and figure it's about the same but wanted to ask before I made the purchase. ANY PICTURES WOULD BE VERY HELPFUL AS WELL. thanks
r4dranger is offline
post #2 of 13 Old 01-16-2018, 11:09 PM
Fire From the Clouds!
Horizon122's Avatar
Quoted: 233 Post(s)
The 05-07 axles are wider then the 99-04's, I believe 37x12.50's will fit. @OCVeloMan would know best.
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 PMF lift on 325/60r20 Nitto M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
post #3 of 13 Old 01-17-2018, 04:00 AM
Quoted: 376 Post(s)
Garage
Your going to need a bigger cutoff wheel if you want that to work IMO.
I have a 8"dual coilover kit and I still rub the plastic when turning hard on 37x13.50x22 Toyo's
New 2019 F350 CCLB Platinum
Last Truck 2006 F350 CCLB KR
I'm out old man. I'm just a pecker-wood who lives in the woods with too many guns. Ya happy?"
BridgerMT is offline
post #4 of 13 Old 01-17-2018, 07:29 AM Thread Starter
r4dranger's Avatar
I'm only guessing but wouldn't your width and probably your offset be a big difference from what my setup will be???
post #5 of 13 Old 01-17-2018, 07:47 AM
Heavy_GD's Avatar
Quoted: 3147 Post(s)
Garage
Feedback Score: 4 reviews
10 wides with -12 are very different than 12 wides with 13.50 and a -44
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is online now
post #6 of 13 Old 01-17-2018, 07:52 AM Thread Starter
r4dranger's Avatar
That's what I figured.... I'm ok with a little rubbing also in that case I'm ok with some trimming too. Just was curious if anyone could tell me how much.
post #7 of 13 Old 01-17-2018, 12:57 PM
Quoted: 376 Post(s)
Garage
Agree... but so is 8 inches to 4 inches.. I'm 11" wide with 13.5"
post #8 of 13 Old 01-17-2018, 01:23 PM
ZMANN's Avatar
Quoted: 4005 Post(s)
I have -12 offset on a 10" rim 37x13.50 Toyo MT 06 F250
and even my 7" lift I could stuff the tire into the inner fender well if I was turning into any driveway that had a little bump ( i trimmed off the front bumper tip )
I did the ziptie trick but ultimately i went with an 8 inch lift and could still just kiss the inner on a hard impact at full turn
if you try this minimal lift idea at least get your front jounce stops set so you do minimal damage
unfortunately you have some open wheel well on these trucks if you really want to keep the turning radius and suspension travel without going to cutout flares
6.0 flush pdf
ZMANN is offline
post #9 of 13 Old 01-17-2018, 01:36 PM
Heavy_GD's Avatar
Garage
What offset are your wheels?
GD
post #10 of 13 Old 01-17-2018, 01:50 PM Thread Starter
r4dranger's Avatar
Thanks guys I just went with 35x12.5s for now and will do some testing later.
ZMANN, Heavy_GD and BridgerMT like this.
