Drop Receiver Recommendations - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
 1Likes
post #1 of 11 Old 09-19-2016, 06:03 PM Thread Starter
ARS1's Avatar
Quoted: 178 Post(s)
Garage
Trucks getting ready to get a 10" lift and 40"s. I do have a 3500lb dump trailer I occasionally pull and a 16' utility trailer but nothing to crazy. Who makes a good drop receiver for that high of a lift? I don't just want to get a cheap one and have it snap as that could be a bad day! Never had to look for one for this much lift before.
My Build Page
'17 F250 6.7L 4x4 Lariat Ult. Shadow Black -Kelderman 6"-8" Air Lift - Fab Fours Premium Bumpers - Amp XL Steps - SmittyBilt 15.5K X2O Wireless Winch - Fuel Crush 22"x14" -70 Wheels - 37"x13.5"x22" Toyo M/T's - Custom Bed Mount Spare Tire / Hi Lift Jack Mount - Horn Blasters Katrina Train Horns - S&B Intake - AMI Blue Demon Hooks - Weigh Safe 2 1/2" Receiver - Smoked Lights - LED Conversion - More To Come...
'18 Camaro ZL1 1LE - Hyper Blue
'18 Camaro ZL1 - White
'18 Jeep JL Rubicon - Blue
'17 Raptor - Shadow Black
Please Subscribe!
ARS1 is offline
post #2 of 11 Old 09-19-2016, 06:10 PM
DMc
6.2 Convert
DMc's Avatar
Quoted: 342 Post(s)
A buddy of mine swears by this one. He drives a Duramax so it's probably overkill for his truck! No relation to Bulletproof Diesel!
https://bulletproofhitches.com
2018 F250 4X4 CC LB 6.2
2004 F250 4X4 CC SB Sold (Miss you Sarah!)
DMc is offline
post #3 of 11 Old 09-19-2016, 07:00 PM
Fummins Mod
junior125's Avatar
Quoted: 2225 Post(s)
Garage
I've seen the diesel bro's advertise them.... soooo there is that, I believe like B&M has a good drop hitch that's adjustable
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #4 of 11 Old 09-19-2016, 07:14 PM
DMc
6.2 Convert
DMc's Avatar
Quoted: 342 Post(s)
Diesel bro's?!? Forget I mentioned it then!
DMc is offline
The Following 2 Users Say Thank You to DMc For This Useful Post:
toad (09-19-2016)
post #5 of 11 Old 09-20-2016, 09:32 AM Thread Starter
ARS1's Avatar
Quoted: 178 Post(s)
Garage
LMAO I'll check them out. Unfortunately the Bro's promote a lot of stuff that a lot of people one here most likely had before they screwed up the mentality people have about lifted diesels... Priuses run from me already for some reason and I don't even blow smoke on them!!!
My Build Page
Please Subscribe!
ARS1 is offline
post #6 of 11 Old 09-20-2016, 10:43 AM
layson's Avatar
Quoted: 84 Post(s)
This has a step and you can get the integrated mudflap setup. The mudflaps easily slide out if you don't want to run them or take your truck to a show.
It also lowers down the electrical trailer plug. Right behind the receiver on the back side is where the trailer plug is re-routed.
They even make a step that plugs into the hitch when you are not towing. So you can step up that and then step on the top of the hitch. They are a very nice product and made for guys who have lifted trucks. There isn't anything out there that has what these have.
layson is offline
post #7 of 11 Old 09-20-2016, 10:57 AM
layson's Avatar
Quoted: 84 Post(s)
You can see the step in the hitch on the last two pictures.
layson is offline
post #8 of 11 Old 09-20-2016, 06:12 PM Thread Starter
ARS1's Avatar
Quoted: 178 Post(s)
Garage
Man do you work for one up? LOL That does look like a sturdy setup for sure. I'll look into that one as well.
My Build Page
Please Subscribe!
ARS1 is offline
post #9 of 11 Old 09-20-2016, 06:39 PM
ars5147's Avatar
Quoted: 211 Post(s)
Look up Gen-Y hitches, they are nice. I've got two 10 inch drop hitches from Diversi-Tech, one for my OBS and 6.4. They are nice too, especially the way they lock and adjust. Next one if I ever need will be the Gen-Y.
https://www.amazon.com/Diversi-Tech-...i-tech+10+inch
https://genyhitch.com/?gclid=CO6tg9qpn88CFUMehgodYV4IOQ
1997 F350 CCLB 7.3
2019 F350 CCSB 6.7 Lariat Sport
ars5147 is offline
post #10 of 11 Old 09-21-2016, 09:12 AM
layson's Avatar
Quoted: 84 Post(s)
No but I have all this stuff on my personal truck and alot of other OUO stuff LOL. I know you will like them. They are better than anything out there. They are one of those items like AMP steps that you are really happy that you have them....LOL... You can tow whatever you want. You don't have to stretch all your wiring out to reach the plug up near the bumper. I even took my trailer plug and installed it up under the truck so you don't see it. Then all the wiring goes down through the inside of the hitch. It also has hooks down low so the chains can hook right up to the hitch. It has a nice shackle on it to pull on crap...LOL. Then when you are not using it you can use it as a step to get in your truck. Then to top it off you can get the mudflap setup that slides right in the back of it. Then if you want you can just throw the mudflaps in the bed of your truck then when you get pulled over for no mudflaps you can slide them in and drive off...LOL
ARS1 likes this.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
DLR
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
