Dust Cap for 7-pin when Unhooked? - Page 2 - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
 13Likes
post #11 of 17 Old 06-11-2018, 06:14 AM
ChrisSki's Avatar
Quoted: 541 Post(s)
I just joined the club. Ordered one. I had been looking at the plug the last time I towed and said to myself, "I wonder how long the metal will stay shiny?" Hopefully a little lonfer with this.
SuperCrutyPS and Got Dirt? like this.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is online now
post #12 of 17 Old 06-11-2018, 06:20 AM
Heavy_GD's Avatar
Quoted: 3095 Post(s)
Garage
Feedback Score: 4 reviews
Maybe we can have a ROTM for plug caps.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #13 of 17 Old 06-11-2018, 10:03 AM
Got Dirt?'s Avatar
Quoted: 177 Post(s)
Garage
Here's my entry!!!
Click For Full-Size Image.
Heavy_GD likes this.
People are like dirt. They can either nourish you and help you grow as a person or they can stunt your growth and make you wilt and die.
Plato
2006 Super Duty F-250 Lariat CCSB: Edge CTS Insight - BPD FICM - Sinister Diesel Coolant Filter - ProComp 20" wheels - Toyo M/T 35's - ReadyLift w/ Bilstein 5100's - 4" MagnaFlow Exhaust - '08 Transmission Pan and Filter..... and a Partridge in a Pear Tree!:wink[3]:
Got Dirt? is offline
post #14 of 17 Old 06-11-2018, 06:46 PM
DieselDC
DieselDC's Avatar
Quoted: 681 Post(s)
I honestly don’t use one . I’ve had them b4 and all it did was corrode up my connections. So I just blow them out every other oil change and seems to work better. Mud sucks.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
DieselDC is offline
post #15 of 17 Old 01-11-2019, 04:14 PM
Got Dirt?'s Avatar
Quoted: 177 Post(s)
Garage
—————signature—————
DieselDC is right --- I just checked mine with the cap on it (had been raining quite a bit the last few weeks) and sure enough, there was some corrosion present. I repositioned the plug so that water won't collect in it (upside down), gave it a good spritz of cleaner and that should do the trick. Everyone should check theirs.
DieselDC likes this.
Plato
post #16 of 17 Old 01-12-2019, 06:19 AM
partyman97_3's Avatar
Quoted: 872 Post(s)
Garage
Originally Posted by SuperCrutyPS View Post
Got my cap today - Got some CRC contact cleaner and some dielectric grease - Cleaned up the contacts, greased the blades and installed the cap.
As usual, I am late to the party, but I sure like those molded plugs.
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is online now
post #17 of 17 Old 01-12-2019, 06:45 AM
Quoted: 318 Post(s)
Garage
When using a cap, you need to position the plug facing upward so it dont collect water, else the connections will sit in a water bath.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
