Carli Suspension - Official Thread - Page 392 - Ford Powerstroke Diesel Forum
 494Likes
post #3911 of 3982 Old 11-22-2018, 06:34 PM
alopez910's Avatar
Quoted: 3 Post(s)
Originally Posted by Alberta Advantage View Post
I just got my ‘18 F350 and had a local shop install a Backcountry 2.0 system with the add-a-pack leaf springs. On your website, it says that 2017+ progressive add-a-packs eliminate the factory block and provides 1/2″ of lift over stock. When they lowered my truck to the ground, the front end was sky high and the rear was squatted. I noticed on the ‘11-‘16 models, the add-a-packs for the level 2.5″ suspensions require Super Duty’s equipped with a 3-5/8″ tall block from the factory will require the factory 2″ tall block to obtain leveled stance with the add-a-pack. I’m just wondering if I should have a block or no block.
You have to use the blocks for the add a pack. The full spring pack are the progressive ones and do not use a block.
2016 F250 King Ranch FX4
Carli Pintop 2.5" with full springs, Ezlynk GDP Tuned, 5" Flo-Pro exhaust, Midwest Street Trans, H&S cold side, S&B intake
alopez910 is offline
post #3912 of 3982 Old 11-24-2018, 08:02 PM
KM05F350's Avatar
Quoted: 3 Post(s)
So does this "superduty bounce" go away with the LT Deaver springs???
I'm looking at the 4 1/2" springs.
KM05F350 is offline
post #3913 of 3982 Old 11-26-2018, 12:44 PM
OCVeloMan's Avatar
Quoted: 200 Post(s)
Garage
I just got my Ď18 F350 and had a local shop install a Backcountry 2.0 system with the add-a-pack leaf springs. On your website, it says that 2017+ progressive add-a-packs eliminate the factory block and provides 1/2″ of lift over stock. When they lowered my truck to the ground, the front end was sky high and the rear was squatted. I noticed on the Ď11-Ď16 models, the add-a-packs for the level 2.5″ suspensions require Super Dutyís equipped with a 3-5/8″ tall block from the factory will require the factory 2″ tall block to obtain leveled stance with the add-a-pack. Iím just wondering if I should have a block or no block.
The 2018 uses no block with the add-a-pack. We've have 2 shops with the same concern; one discovered a leveling puck under the factory coil bucket, the other removed the lowermost leaf spring from the factory pack. The stance was rectified when these issues were.
OCVeloMan is offline
post #3914 of 3982 Old 11-26-2018, 12:48 PM
OCVeloMan's Avatar
Quoted: 200 Post(s)
Garage
The Deavers will allow the axle to move more translating into less jounce making its way into the frame. That said, a lower spring rate is only that, it takes the rest of our system to control these springs.
All the suspension in the world won't fix a flexy-frame if that's your issue but i never had it on my 2006 or 2016 with my Carli Kits.
Skyd Ram likes this.
post #3915 of 3982 Old 11-26-2018, 03:46 PM
Alberta Advantage's Avatar
Quoted: 91 Post(s)
Pretty sure I now know where my problem is. The lowermost leaf springs are sitting in my backseat and not in the leaf pack but I still have the block installed. Looks like Iíll have them remove the block and add the lowermost leaf back in and Iíll be all set.
Appreciate the help.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3916 of 3982 Old 11-26-2018, 04:40 PM
OCVeloMan's Avatar
Quoted: 200 Post(s)
Garage
When you say lowermost, are you referring to the overload (1" thick spring that doesn't follow the contour of the pack) or the lowermost leaf spring from the 4-leaf pack & the overload?
post #3917 of 3982 Old 11-26-2018, 04:43 PM
Quoted: 91 Post(s)
It would be the overload that they took out.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #3918 of 3982 Old 11-26-2018, 04:45 PM
OCVeloMan's Avatar
Quoted: 200 Post(s)
Garage
That would be correct, the overload is replaced with the add-a-pack. How many leaf springs are in your main pack, not including the add-a-pack?
Take some pictures and send them over to [email protected] so i can take a look; front and rear! Lower spring buckets from the front too, please!
post #3919 of 3982 Old 11-26-2018, 07:04 PM
Skyd Ram's Avatar
Quoted: 220 Post(s)
Ok,
So just to be clear, you have the mini packs in the rear along with the factory 3" block? And they only removed the rear overload leaf and the truck is still taller in the front?
Double check the part numbers on the coils and take a pic of where the coils mount at the top and the bottom.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | INNOV8 Wheels| aFe Power | S&B | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #3920 of 3982 Old 11-26-2018, 07:24 PM
Quoted: 91 Post(s)
Originally Posted by Skyd Ram View Post
Ok,
Mini packs and the stock block in the back. The bottom overload is removed. Truck is taller in the rear, not the front.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
