Carli Suspension - Official Thread - Page 302 - Ford Powerstroke Diesel Forum
 493Likes
post #3011 of 3969 Old 02-27-2016, 12:43 PM
Quoted: 3 Post(s)
did you ever get the low tire light out or is there some way to readjust the pressure
Gonup2 is offline
post #3012 of 3969 Old 02-27-2016, 06:31 PM
Quoted: 66 Post(s)
My 4.5" Dominator Bypass setup order should be placed on Monday. Going to be hard to wait 4+ weeks for it to get built and ship!
Wes
wesjtx is offline
post #3013 of 3969 Old 02-27-2016, 08:14 PM
DesertDaveH's Avatar
Quoted: 14 Post(s)
Just talked to my buddy that works at Ford, he said he has a programmer that reprograms the sensors in each wheel. He said it takes 5 seconds a sensor. I'm still trying different pressures so until I figure that out I'm going to hold off.
Once I get it fixed I'll post it. Hoping for a good range so I can go up or down 5-10 PSI as needed.
2015 F250
Carli BackCountry 4.5"
Fuel Beast Wheels
37" Toyo MT's
DesertDaveH is offline
post #3014 of 3969 Old 02-28-2016, 02:15 PM
DIGMAR's Avatar
Quoted: 28 Post(s)
So I posted this in a seperate thread, but figured I'd get a response here:
I got my Carli adjustable track bar installed the other day, but have some questions about the set up. Axle seems to be almost dead center. Only a few mm difference between passenger and driver sides. But the himes joint on the frame side seems to be off. Photos attached below, you can see its rolled all the way forward/down and the ball joint side is angled towards the rear of the truck. The ball joint is centered horizontally (in relation to the passenger/driver side of truck) but pushed back. I've loosened the lock but on the frame side and rotated the bar, but it always seems to settle like the photos. Is this normal, or what am I jacking up???
2012 F250 Lariat CCSB SRW:
H&S XRT w/ Gearheads tunes, Edge CTS, 5" FLO PRO DP Back w/ Muffler
S&B CAI, EGR Block Off Plates, No Limit CCV
Retro HIDs, ProComp 2.5" Stage3, Carli Track Bar, BDS Radius Arms, Fox 2.0 IFPs
DIGMAR is offline
post #3015 of 3969 Old 02-28-2016, 07:45 PM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1682 Post(s)
Garage
You can't clock the hein a little ?
Regardless it is fine at that angle as well.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3 CAC Pipes & CSF 7106 I.C.
4 Diamond Eye SS Exh System
W/two 4 SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #3016 of 3969 Old 02-28-2016, 07:53 PM
DIGMAR's Avatar
Quoted: 28 Post(s)
Yeah. I've adjusted it a few times, but always seems to settle back there. Just want to be sure it wasn't going to cause any issues down the line with it up against the edge of the bushing sleeve. Will keep messing with it.
DIGMAR is offline
post #3017 of 3969 Old 02-28-2016, 08:17 PM
JetExpress_6.7's Avatar
Quoted: 147 Post(s)
Garage
That's the way mine is Digmar. Not sure if it's wrong or not but it's been that way since install...
JetExpress_6.7 is offline
post #3018 of 3969 Old 02-29-2016, 09:26 AM
OCVeloMan's Avatar
Quoted: 200 Post(s)
Garage
Perfectly normal! Mine and Sage's sit like that at ride height as well. There is plenty of movement (misalignment) in that joint for the linear travel stroke of that front axle.
JetExpress_6.7 likes this.
OCVeloMan is offline
post #3019 of 3969 Old 02-29-2016, 09:28 AM
OCVeloMan's Avatar
Quoted: 200 Post(s)
Garage
Thought you guys would enjoy some pictures I took on my trip to Prescott, AZ this weekend. This was the drive from Prescott to Crown King, AZ:
post #3020 of 3969 Old 02-29-2016, 12:16 PM
Quoted: 66 Post(s)
Nice pics Dan, truck looks really good. How did it feel? All the motor work, suspension fine tuned, etc. should have that thing feeling like a million bucks huh?
Wes
wesjtx is offline
