Should I do ball joints - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Cole440
  • 1 Post By jman37
post #1 of 10 Old 07-28-2019, 06:13 PM Thread Starter
Quoted: 8 Post(s)
Hello all,
I have a 2009 F250 4x4 crew cab 6.4. I have a seized auto hub which i haven’t noticed until in turn it has ruined one of my axle shaft u-joints where it’s horrendously squeaking despite me greasing them regularly so i need to hack out the broken auto locker and then get the axle shaft out and replace all the appropriate seals. I am also going to replace the wheel hub bearing assembly So I am getting into the thick of it with this thing. Now my question is I don’t believe i have any ball joint movement, i recently had a Ford shop alignment after putting leveling coils and new shocks all around, and there was no mention of balljoint problems, but I feel with 99k on the truck that i might need them soon. Since I’m pulling all that crap to get to the axle shafts should/would I/you do the ball joints now even if they are not “bad”
Thanks
PMme if you need to
Thanks
Chris in Maine
09 6.4 Super duty Lariat
AMSOIL Fluids where I can..
DieselSite coolant and transmission filtration
Banks RamAir
Mainepowerstroke is offline
post #2 of 10 Old 07-29-2019, 03:17 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 950 Post(s)
Feedback Score: 3 reviews
I had 289k on my old 2006....never needed ball joints. If it's not broke.....you know.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 10 Old 08-07-2019, 06:50 AM
wiredgeorge's Avatar
Quoted: 25 Post(s)
I have owned a bunch of Ford pickups and they all needed front end steering stuff at a bit less than 100K miles. Probably rural and poor country roads but ball joints were definitely in all the front end rebuilds. The front end on a Superduty real heavy and like most real heavy front end trucks likely would not do harm to go through the whole thing and be done with issues for the next 100K miles.
2006 Ford F-350 6.0L Auto CC 4WD LB
2002 Keystone Cougar 278EFS
2006 GL1800 Roadsmith trike
Mico TX
wiredgeorge is offline
post #4 of 10 Old 08-07-2019, 09:02 AM
Cole440's Avatar
If you do, I would stay away from Moog, had nothing but problems with more than one set. Go XRF or another brand.
Mike Gs likes this.
Cole440 is offline
post #5 of 10 Old 08-07-2019, 10:58 AM
Quoted: 25 Post(s)
I used Detroit Axle and don't have enough miles to see if it lasts 100K but so far so good.
Mico TX
post #6 of 10 Old 08-07-2019, 12:01 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 623 Post(s)
Feedback Score: 11 reviews
how much play is in them? if very little no none, i wouldnt change them out.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #7 of 10 Old 08-07-2019, 12:17 PM
jman37's Avatar
Quoted: 400 Post(s)
Garage
If you do replace them go with Dana/Spicer, top quality and OE stuff.
Mike Gs likes this.
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's - Sold
'17 Grand Cherokee SRT - Stock
'97 SVT Cobra - Few things
'88 Mustang LX - Built 306ci, built AOD, 4.10's - Sold
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is offline
post #8 of 10 Old 08-07-2019, 08:14 PM
Cole440's Avatar
They are good! Only reason I we didn't go with OE on our super duty is they were not greasable IIRC.
Daily Driver: 1996 RCLB F350, 4x4 Factory 4.10 LSD, 5-Speed and a 7.3 of course!
Dads / Family rig: 2002 CCLB F350 4x4 4R100 7.3
Fun rig: 1994 4runner 3.0 Straight Axle swapped & leaf sprung
Coming up on 350,000 miles on the 96' & never been into the motor with the exception of injectors! (by choice not necessity)
Cole440 is offline
post #9 of 10 Old 08-07-2019, 08:23 PM
ZMANN's Avatar
Quoted: 4033 Post(s)
i got 60 k out of my first set ( Ford did them under warranty and i did my second set around 110,000
i am sure thye could have gone a longer but they were dry ( I went OEM Spicer )
6.0 flush pdf
ZMANN is online now
post #10 of 10 Old 08-10-2019, 07:05 AM Thread Starter
Quoted: 8 Post(s)
So I had ZERO play in them, and I tried to get them to move, I had a 5foot steel bar under the tire and tried to lift in all directions, side play and front play.. nothin, I was shaking the whole truck but no movement in Balljoints. So I opted not to do them. I didn't really need to change my hubs either but I did since they were out of the truck. was a good project. If anyone does this work ever, you NEED the seal and axle installment tool. Its a big hunk of steel that cost 60-90 bucks on Amazon, but you cannot do this job without it. I borrowed a balljoint press from a friend who is a on-the road mechanic and it made quick work replacing the Ujoints. all in all 6 hrs to do bother sides taking my time..
