What is the name of this power steering hose? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-18-2019, 09:43 AM Thread Starter
Hello everyone, long-time lurker first time poster from Sooke, BC Canada.
I have a 2000 Ford f-350 with the 7.3 L diesel. Single rear wheel and automatic transmission, four-wheel drive if that is important.
I have developed a leak in my power steering. Upon reading on here it seems very likely that it is the hose that rubs against the shock mount. I was able to run my hands and fingers on it and I definitely feel a deep rub point. So if it fixes the problem or not this hose definitely needs to be replaced.
But I am unsure which hose it is, it seems like there are two high pressure power steering hoses. Could somebody please guide me and tell me which hose to ask for at the parts store?
for reference, this whole is routes up towards behind the master cylinder, I'm assuming that is into the hydroboost. It routes into the left side as I am looking at the engine from the front of the vehicle.
Any help is greatly appreciated. also, I know this is cheap but is it possible to get a piece of rubber and wrap it around the leaking area and hose clamp it on there very tight? I kind of need to get the truck out of where it is sitting.
Thank you again.
Cheers,
Luke
Luke Nelson is offline
post #2 of 5 Old 07-18-2019, 10:05 AM
voodooridr's Avatar
Quoted: 903 Post(s)
The hose is a 2C3Z-3A717-BA you might be able to find one at a local parts store
Sent from my SM-G960U using Tapatalk
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
post #3 of 5 Old 07-18-2019, 11:09 AM Thread Starter
Thanks for the quick reply. I looked online and it lists that part number for gas engines, is this the right one for my diesel truck?
Also, would you know if it is the pump to hydroboost or hydroboost to gear line? That is what my part house is waiting to know.
Thank you again.
Luke
post #4 of 5 Old 07-18-2019, 12:16 PM
voodooridr's Avatar
Quoted: 903 Post(s)
That's the pump to hydroboost line
And you are indeed correct , my catalog has 2000 applications reversed
1C3Z-3A717-AA is the 7.3 hose
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
PHP Insight PRO
post #5 of 5 Old 07-18-2019, 08:44 PM Thread Starter
Thank you. I was able to pick it up tonight. Hopefully tomorrow I can replace the hose.
