Lowering 2005 f350: drag link and track bar - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-22-2019, 01:45 PM Thread Starter
DieselDC
DieselDC's Avatar
Quoted: 677 Post(s)
I bought a “ReadyLift 67-2535 Track Bar Bracket “ to lower down to 5”. Went well. Front bolt sucked - took 20mins to thread it on without cross threading.
Bought a 5” pitman arm - it’s was the same size and drop as the one I took off (10” lift b4). Now I’m regretting it after the fact. The drag link and track bar are not parallel.
What do you guys think? Okay to drive around for the time being? I’m thinking a new pitman - any one in particular????
Thanks
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
DieselDC is online now
post #2 of 18 Old 06-22-2019, 02:36 PM
ZMANN's Avatar
Quoted: 3803 Post(s)
if it handles fine and has no bump steer then your ok the track bar being parallel with the drag link can be misleading since the center of the mount is higher than the actual trac bar ,, bar
also check your stabilizers you may need to flip the mounts to the below the tie rod bar option if suspension makes contact under compression and don't forget to try different turn percentages now
6.0 flush pdf
ZMANN is offline
post #3 of 18 Old 06-23-2019, 07:03 AM Thread Starter
DieselDC
DieselDC's Avatar
Quoted: 677 Post(s)
Could you explain this one? You have a picture of “flip the mounts...”?
—————signature—————
post #4 of 18 Old 06-23-2019, 07:37 AM
ZMANN's Avatar
go to top gunz custom and look for the instruction
but basically you mount the tie rod sides under the tie rod instead of on top and the shocks mount under versus over the bracket
but you may still be fine with 5" of lift
however, it is prudent to check clearance and especially the bolts on the adjuster sleeve on the passenger side
6.0 flush pdf
ZMANN is offline
post #5 of 18 Old 06-23-2019, 07:42 AM
ZMANN's Avatar
6.0 flush pdf
ZMANN is offline
post #6 of 18 Old 06-23-2019, 07:28 PM Thread Starter
DieselDC
DieselDC's Avatar
Quoted: 677 Post(s)
I cut my springs. Weren’t going to spend another $300 on springs. What I should have done is cut my original springs that I took off. Turned out pretty good.
Now I need to order some new sway bar end links.
—————signature—————
post #7 of 18 Old 06-23-2019, 08:14 PM
ZMANN's Avatar
i need new end links also please let me know what you find ( i can't remember if the bushing is replaceable ?)
i see yours are stock with an extension
6.0 flush pdf
ZMANN is offline
post #8 of 18 Old 06-23-2019, 08:27 PM Thread Starter
DieselDC
DieselDC's Avatar
Quoted: 677 Post(s)
Sure thing. I ordered through amazon.
—————signature—————
post #9 of 18 Old 06-23-2019, 08:34 PM
ZMANN's Avatar
not a huge MooG fan but those look ok
thanks
6.0 flush pdf
ZMANN is offline
post #10 of 18 Old 06-24-2019, 03:59 AM Thread Starter
DieselDC
DieselDC's Avatar
Quoted: 677 Post(s)
No worries. It’s a hit or miss but I’ve had really good luck with them. There’s also another set I also bought while back for the 7.3. $40 for booth vs for one. Off brand but dang, they’re still going. No mushrooming or drying of the rubber.
It’s like the deal with yellowtop batteries- I will always recommend them. Some get real heated just vc I say I like them . Some people hate them and swear they are chitty but I just bought another set for the 6.0 as I waited for my batteries to die.
—————signature—————
