Caster after lift question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-07-2019, 05:38 PM Thread Starter
Hello, I have a 2006 250 4x4. I put an 8” rough country 4 link lift kit on. I was wondering if there is a way to measure the caster angle with an angle finder. Also what is the recommended caster? Thanks
White trucks matter is offline
post #2 of 8 Old 04-13-2019, 05:57 PM
jetjock15's Avatar
Quoted: 286 Post(s)
You’d have to measure exactly between top and bottom ball joint in knuckle. Best to get on an alignment machine. The kit should have come with eliptical or fixed offset adjusters, they all do. And the kit should include which way they are supped to be installed. Lots of kits use Same offset drilled alignment piece for 6 or 8” kit just flipped around with offset other direction. Did your kit come with instructions tha address this? Shouod have
19 F450. Hauls my toys. Dumont regular
Build thread:
Truck pics on IG @ Jetjock15
Iíve owned previous vehicles but I wonít waste the forum space to list them, oh ya, and you donít care
jetjock15 is offline
post #3 of 8 Old 04-14-2019, 07:04 AM Thread Starter
My kit came with adjustable rod ends. The problem is I also added a 2” spacer below the springs. Now I don’t have enough adjustment with the rod ends to give me enough caster. I’m trying to decide the best way to correct the problem. First I have to determine how much more caster I need. Option 1, cut the lower 4 link rod (the one that has the adjustable end) and add a solid steel rod inside and lengthen them a couple inches or cut and shorten the upper 4 link arm. The fixed one.
Now before this turns into a thread about how I shouldn’t have added the spacer, I understand. If this was my daily driver I would have never done that. I drive this truck only a couple of times a month and very short distances. No highway driving.
ID:	717469   Click image for larger version
post #4 of 8 Old 04-14-2019, 07:06 AM Thread Starter
Also I threw away the bolt that came with the lower spacer and bought a grade 12.9 socket cap bolt and used red thread lock.
post #5 of 8 Old 04-14-2019, 07:23 AM
jetjock15's Avatar
Quoted: 286 Post(s)
Ah I see. You tried driving it as is?
Build thread:
post #6 of 8 Old 04-14-2019, 08:37 AM
00t444e's Avatar
Quoted: 522 Post(s)
You can measure caster with a magnetic angle finder on the bottom of the knuckle. 4-5 degrees is what most straight axle vehicles spec.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #7 of 8 Old 04-14-2019, 09:12 AM Thread Starter
Yes I have. Before I maxed out the caster it was awful. It wandered all over and was wild when I hit a bump. Now I set the rod end all the way out (I left 1” of thread still inside the 4 link tube) now it’s a little better but I still think it needs more.
post #8 of 8 Old 04-14-2019, 09:12 AM Thread Starter
Ok thank you
Similar Threads
Thread Thread Starter Forum Replies Last Post
FUEL PUMP / LIFT PUMP QUESTION eryan2369 99-03 7.3L General Discussion 13 11-05-2016 04:35 AM
Lift Kit Question f250ghost 6.7 Exterior Discussion (2011-2016) 7 09-23-2016 04:44 AM
Horrible steering after caster adjustment Zejokee 6.7 Problems Forum (2011-2016) 2 08-25-2016 12:22 PM
Post Lift Caster Question (bump steer) charbaugh Suspension & Steering 8 08-04-2016 12:37 PM
Lift or No Lift, that is the question Logan Powerstroke Off Roading 10 05-03-2007 01:31 AM
