Dropping from a 7 to 4.5" icon - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-18-2016, 11:59 AM Thread Starter
Big_Smokey's Avatar
Quoted: 10 Post(s)
I am wanting to go smaller. Stupidly I had a 4.5 to start with and ended up buying a 7" icon and selling the 4.5
I'm trying to remember what all I will need to swap. There wasn't a bunch of stuff to do if I remember.
I know I should need a different pitman arm
Different springs
Shocks
And smaller OUO rear block for my traction bars.
I have pmf 3-link arms up front.
Any thing else?
Big_Smokey is offline
post #2 of 13 Old 10-18-2016, 01:12 PM
Skyd Ram's Avatar
Quoted: 220 Post(s)
Different springs
Shocks
Any thing else?
Sounds like you have it figured out.
In most cases you would need a stock pitman arm and track bar drop bracket and then run an adjustable track bar if you don't already have one.
Obviously shorter coils, shocks, and rear blocks would be needed. Then just some adjustments and alignment.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | INNOV8 Wheels| aFe Power | S&B | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #3 of 13 Old 10-18-2016, 01:42 PM Thread Starter
Big_Smokey's Avatar
Quoted: 10 Post(s)
I have the icon adjustable track bar also.
Do they make a pitman arm for 4.5" lifts or is it not needed
post #4 of 13 Old 10-18-2016, 01:54 PM
Quoted: 42 Post(s)
The 4.5" Icon kits do not spec a drop pitman. Just make sure you aren't using the old track bar bracket from the 7" kit with a stock height pitman.
[URL=
dlr
Free shipping on Carli Suspension to the US and Canada!
424-241-3252
CJCOffRoad is offline
post #5 of 13 Old 10-18-2016, 04:49 PM Thread Starter
Big_Smokey's Avatar
Quoted: 10 Post(s)
No I was going to use the adjustable track bar only.
post #6 of 13 Old 10-18-2016, 07:34 PM
Skyd Ram's Avatar
Quoted: 220 Post(s)
Perfect,
Adjustable track bar using the stock track bar bracket and pitman arm is the way to go at that height.
888-886-2480
Skyd Ram is offline
post #7 of 13 Old 10-18-2016, 11:42 PM
JesseKK's Avatar
Quoted: 90 Post(s)
Garage
@ big smokey, how do u like the icon track bar? I've been looking at different track bars.
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
post #8 of 13 Old 10-19-2016, 06:36 PM Thread Starter
Big_Smokey's Avatar
Quoted: 10 Post(s)
It's been fine. When I bought mine I had to pay extra for the heim joint upgrade. It's been on my truck for 80000 miles and has worked great. It gets rid of the rubber bushings like the OEM has.
I'd recommend the 3-link arms over everything. It improved my steering allowing castor to be set more positive then spec.
The Following User Says Thank You to Big_Smokey For This Useful Post:
JesseKK (10-19-2016)
post #9 of 13 Old 10-21-2016, 11:30 PM Thread Starter
Big_Smokey's Avatar
Quoted: 10 Post(s)
What coil springs and shocks should I go with.
I had the icon 4.5 and they seemed a lot stiffer then their 7" coils. I have PMF 3-link and OUO rear blocks now. Unsure about shocks
post #10 of 13 Old 10-22-2016, 12:49 AM Thread Starter
Big_Smokey's Avatar
Quoted: 10 Post(s)
Also do I have to put a stock pitman arm back in if I'm still at 4.5" of lift vs the 7" icon.?
