2017-2019 6.7L Ford Transmission Cooler Kits! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-18-2019, 02:35 PM Thread Starter
Strictly Diesel's Avatar
Quoted: 2 Post(s)
We've tested the crap out of this setup and finally got it released. Massive temperature drops and control.
I was a complete ahole to my personal 2017 F450 with my 18k# 48' race trailer, fully loaded, in the Arizona desert in the middle of August. Pulling hills under heavy throttle, during a regen (all 4 egt sensors around 900F)...EOT was at 240F+, ECT at 217F and the trans was a happy 194F.
The hottest I was able to get the trans, trashing on it hard, was 220F (EOT was well over 250F and ECT was over 230F if I remember right, couldn't get a picture)...and when I laid off and just drove the truck normally, it was back down below 200F within a few miles.
If you own one of these trucks, you've probably also noticed that the faster you go (even unloaded), the hotter the trans gets. My F450 (4.30 gears and short tires) on the highway at 80mph (2500ish rpm is I remember right) would see trans temps in excess of 220F UNLOADED before this cooler went in.
Simply put, this thing WORKS!
See captioned pics below...
COOLER INSTALLED BEHIND AN OEM GRILLE
PRIMARY TEST TRUCK AND TRAILER
Note: We tested with the OEM grille and the mesh grille shown here. The additional airflow from the aftermarket mesh grille showed about a 5F improvement. The numbers above are with the mesh grille. If you want the maximum amount of temperature drop, consider a grille upgrade as well. If you retain the OEM grille, you will still see a very significant temperature drop as our install kit places it right behind the largest openings.
MONITOR DURING ABOVE MENTIONED PULL...
TFT F is the OEM trans temp probe in the valve body
TPanTmp F is an Edge sensor installed in the trans pan for verification
VB temp being hotter is expected and normal
Check out the product details and such at the link below:
https://www.strictlydiesel.com/p-421...ooler-kit.aspx
Dennis Schroeder - Co-Owner of Strictly Diesel
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Race Truck :: 5980# / 10.965 @ 124mph / Best 60' of 1.54 ... with "Built" Race Engine (Nitrous)
Strictly Diesel is offline
post #2 of 6 Old 02-18-2019, 02:37 PM Thread Starter
Quoted: 2 Post(s)
We have kits for 11-16 trucks in the works as well, hoping to have those shipping in the next 60 days.
post #3 of 6 Old 10-09-2019, 05:42 PM
swatdoc's Avatar
Quoted: 54 Post(s)
Garage
Hey guys I see the 11-16 kits are out now. Could you post, PM, or somehow get me the install instructions so I could see those prior to purchase? Thanks
mod added = @Strictly Diesel
swatdoc is offline
post #4 of 6 Old 10-10-2019, 09:00 AM Thread Starter
Quoted: 2 Post(s)
Sorry, forgot to upload them to the website. If you are on the product page and you have entered your vehicle year, make and model, there is a download link now (to the left of the "add to cart" button).
https://www.strictlydiesel.com/p-423...ooler-kit.aspx
post #5 of 6 Old 10-13-2019, 08:17 PM
swatdoc's Avatar
Quoted: 54 Post(s)
Garage
Thanks - doesn't look hard at all. I did have to move my stock trans cooler about 1/2" to clear a new front bumper, but I don't see that being an issue.
swatdoc is offline
post #6 of 6 Old 10-14-2019, 09:07 AM Thread Starter
Quoted: 2 Post(s)
The 11-16 setup is actually a very easy installation!
Similar Threads
Thread Thread Starter Forum Replies Last Post
2017 Ford F350 Lariat 10K mile review thekroog General 6.7 Discussion (2017-2019) 6 09-11-2018 04:28 PM
FORD Super Duty (11-16) Lighting Kits !!! Baja Designs Baja Designs 15 06-21-2018 08:45 AM
BDS Announces New SEMA Project: 2017 Ford Super Duty "Project Ascension" BDS Suspension BDS Suspension 14 11-03-2016 06:50 AM
Mishimotos Secondary Radiator R&D Thread for 11-16 6.7L Mishimoto 6.7 Performance Parts Discussion (2011-2016) 6 10-25-2016 05:26 AM
