Help me convince my dad my truck needs a tune - Ford Powerstroke Diesel Forum
Powerstroke.org Builds & Projects Post your builds & projects here
 15Likes
post #1 of 32 Old 08-22-2019, 01:28 PM Thread Starter
Jakeweber's Avatar
Quoted: 2 Post(s)
Im in high school and recently deleted and straight piped my truck I have a 6.0 and it was also bulletproofed when I bought it. It came with an ancient bully dog tuner and During one of the many times I was switching between tow tune and performance the tuner for some reason put the 6.4 performance tune on it instead of the 6.0 tune and ever since then my dad hasn’t let me switch the tune he thinks no matter what i do to the truck its going to blow up. I was going to get a mild quick tricks tune that was meant for straight piped and deleted trucks but I need more points to bring up in the discussion thanks for any help 🙏🏻
Jakeweber is offline
post #2 of 32 Old 08-22-2019, 01:42 PM
MSM
MSM's Avatar
Quoted: 16 Post(s)
Garage
He is right...
Heavy_GD likes this.
MSM is offline
post #3 of 32 Old 08-22-2019, 02:19 PM
ChrisSki's Avatar
Quoted: 554 Post(s)
If the anything happens to the truck, who pays for it? These trucks can costs thousands of dollars to fix. Do you really have $6k cash to do a head gasket job? If you can afford, than you got a leg to stand on, but wobbly. Even if you could afford it, that money would be much better spent elsewhere.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #4 of 32 Old 08-22-2019, 02:36 PM
00t444e's Avatar
Quoted: 559 Post(s)
With a 6.0 no head studs = no tune but factory, until you save up enough to properly bulletproof it or get something else.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #5 of 32 Old 08-22-2019, 03:05 PM
darianmacdonald's Avatar
Quoted: 23 Post(s)
Yeah by the sounds of things, I’d just leave it stock, leave that bully dog out of it too. And during the “many times” you’ve been swapping between the performance and tow tunes all you’ve been doing is confusing the tranny. Makes for one unhappy 5R110, and in the end could cost you (or your dad) a transmission as well. Not to mention the trans tuning on those devices isn’t good to begin with.
Sent from my iPhone using Tapatalk
2006 CCSB Lariat F-350
304,XXX KM
ARP studs, EGR Delete
SCT SF3 w/ GH & IDP Tunes
BW SXE 62/68/.83AR, Irate T4 Kit
4" Volant Turbo back exhaust
Driven Diesel RR w/ Fuelab Regulator
Isspro Boost, Fuel Pressure, Oil Pressure, HPOP Pressure Gauges
Edge Insight Monitor
FS2500 Oil Bypass Filtration
IDP Tuned 58V FICM
Coolant filtration
R4 Rear Air Ride
Bilstein 5100's
2-Way Compustar Remote Start/Alarm
Misc. mods
darianmacdonald is offline
post #6 of 32 Old 08-22-2019, 03:17 PM
hansel's Avatar
Quoted: 360 Post(s)
If you have a butt load of money laying around "Go for it" because you will blow it up. Treat it like it's the first and last truck you will own. You obviously don't care about paying for anything if you want to go out and race the truck around, that is the problem today, kids do appreciate what they have.
hansel is offline
post #7 of 32 Old 08-22-2019, 06:18 PM Thread Starter
Jakeweber's Avatar
Quoted: 2 Post(s)
I honestly want the best for the truck and talking to some family friends and they were saying I should get a tune for it due to the fact that I changed the way the engine was working. I was looking at the 50hp tow tune because I do plan on doing some towing. Would a small tune like that still be a bad idea it is head studded. Ive been doing my research on what would be best and have seen plenty of good things about Vivians tunes.
post #8 of 32 Old 08-22-2019, 06:22 PM Thread Starter
Jakeweber's Avatar
Quoted: 2 Post(s)
Everything on this truck I am paying for and if something were to happen I have enough money to spare. Im not looking to make it a race truck but I want it to run well with the modifications I have done.
post #9 of 32 Old 08-22-2019, 06:27 PM
MSM
MSM's Avatar
Quoted: 16 Post(s)
Garage
I'm not a mechanic, but I would say that you don't want to run your truck with the wrong tune, the way it is now. So, tell him that your truck is screwed up now and you need to get it right with the new tune. Then you are your going to leave it alone. Good luck.
MSM is offline
post #10 of 32 Old 08-22-2019, 07:20 PM
hansel's Avatar
Quoted: 360 Post(s)
Then I was wrong about you then, most kids don't pay for stuff. Glad you have different priorities, but I'd take it easy on a tune.
hansel is offline
