99 7.3 Powerstroke 800hp - Ford Powerstroke Diesel Forum
Powerstroke.org Builds & Projects Post your builds & projects here
 2Likes
post #1 of 30 Old 03-28-2019, 11:01 AM Thread Starter
I have a project motor out of a 1999 f250 looking to make 800 hp any suggestions on parts to get there on a budget. injectors cams valves and springs rods etc.
997.3merk is offline
post #2 of 30 Old 03-28-2019, 11:59 AM
jman37's Avatar
Quoted: 247 Post(s)
Garage
Subbed....
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's
'88 Mustang LX - Built 306ci, built AOD, 4.10's
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is offline
post #3 of 30 Old 03-28-2019, 04:03 PM
Hate stupid people
CloverLeafFarm's Avatar
Quoted: 274 Post(s)
Lol! I love these threads because 95% of them never finish due to $$$
1. Are you ready for a $20,000 investment IF your serious?
2. Trucks purpose? Sled/drag ?
3. Call Swamps or Carson Stauffer
Illiana Strokers DICtator
EFI Live tuned 6.7
CloverLeafFarm is offline
post #4 of 30 Old 03-28-2019, 04:34 PM
00t444e's Avatar
Quoted: 522 Post(s)
400/400 injectors, a better HPOP, a full regulated return fuel system with a high flow pump or dual factory pumps, T4 turbo setup, with an S475 or S480 turbo, head studs, valve springs, exhaust system, and a Hydra with custom tuning will get you close. You will be at the edge of what the stock bottom end can support at that point so have a spare engine and money saved up to build a better bottom end in case you throw a rod through yours. Also you will need gauges, a fully built transmission if auto, or a dual disc clutch if manual, and traction bars.
02_7.three likes this.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #5 of 30 Old 03-29-2019, 04:20 AM
02_7.three's Avatar
Quoted: 63 Post(s)
Garage
I think 95% is generous lol. I've never seen one finish. Heres a good starting point....
https://www.gohypermax.com/productdi...c-8df2dccc5adb
But in all seriousness you need to be ready to have an open wallet. I've seen some local 7.3 sled pulling motors go together and its not cheap. If you actually want to hit 800 reliably you should seriously consider doing a full motor build. It would be a shame to see that thing blow apart after all the time and $$ spent.
2002 F-250 ECSB ZF6
FF 205/30's, KC 300X 63/73 .84, South Bend Clutch, CNC Fab 4 Line Feed, AEM 400LPH, PHP Tuned
02_7.three is offline
post #6 of 30 Old 03-29-2019, 04:55 AM
Hate stupid people
Quoted: 274 Post(s)
I've been called that before.
I look back on the $$ I spent just to get my 7.3 to 600 rwhp I can almost puke right now. Even though it was a hot setup and loved traveling all over Illinois/Indiana pulling and racing, i still wasted a lot of $ on the platform before I realized it was to late.
EFI Live tuned 6.7
post #7 of 30 Old 03-29-2019, 12:56 PM Thread Starter
what brand for specific parts would you recommend using I have a compound turbo setup for it just need suggestions for internals
post #8 of 30 Old 03-29-2019, 01:45 PM
Hate stupid people
Quoted: 274 Post(s)
your turbo setup should play hand in hand with your injectors as well as your custom tuner.
who have you spoken with that has a legit 800 hp 7.3 truck or setup?
EFI Live tuned 6.7
post #9 of 30 Old 03-29-2019, 02:02 PM
Quoted: 83 Post(s)
20 to 30 grand for the engine, another $5 grand for Dyno time 7 to 8 grand for a transmission, as mentioned before your probably going to toss rods so custom made Titanium rods and crank, looking at another 20 thousand just for those.
Here I'll just make it real easy, do you have about $100,000 to dump in something your going to have to hire and engineering staff to design and most likely blow one up on the dyno the first time? like this,,,,,
get ready yours will look like that the first time you spend the money
RollenCoal is offline
post #10 of 30 Old 03-29-2019, 06:35 PM
00t444e's Avatar
Quoted: 522 Post(s)
If your paying 20-30 grand to build a 7.3 you are getting ripped off. You can build one for half of that.
00t444e is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mishimoto 2008-2010 6.4L Powerstroke Aluminum Degas Tank R&D Mishimoto 6.4L Performance Parts Discussion 6 03-19-2019 10:37 AM
New Mishimoto 2008-2010 6.4L Powerstroke Replacement Radiator Mishimoto Vendor Jungle 0 02-15-2019 12:41 PM
Green Horn of Powerstroke Abram Spectre General Diesel Discussion 3 07-28-2016 03:55 PM
1999 Powerstroke - Be Gentle - I'm New michaelsmalley 99-03 7.3L Powerstroke Problems 5 10-16-2006 09:45 PM
