6.0 powerstroke project - Page 5 - Ford Powerstroke Diesel Forum
Powerstroke.org Builds & Projects Post your builds & projects here
 32Likes
post #41 of 60 Old 06-06-2017, 08:41 AM Thread Starter
Quoted: 4 Post(s)
Help please! Getting ready for fuel lines.
So I'm on the last major installation, fuel tank and fuel lines, I went ahead and purchased some fittings, and I'm going to added them to the end of the factory fuel lines once I cut them, and I was wondering if this would be the best approach, I will basically cut the factory lines, and flare them, then I will add this fittings to the ends, and them the rest will be soft lines all the way to the fuel tank.
SparkyF250 likes this.
F100stroke is offline
post #42 of 60 Old 06-10-2017, 12:45 PM Thread Starter
Quoted: 4 Post(s)
Help with fuel tank!
So I was confused on where the fuel tank used to be mounted before, and today when I went to install it, I realized that it will hit the transfer case, I have no room to move it back side it will also hit the rear axle, so I was wondering if there is a way to cut it and patch it up, to make it shorter, what do you guys think? On the picture I need to cut all that in front of my finger to the right.
post #43 of 60 Old 06-10-2017, 01:07 PM
SparkyF250's Avatar
Quoted: 3309 Post(s)
Garage
Ask our resident custom builder, @h0trod
The guy who hasn't posted any new pics of his latest 6 door
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #44 of 60 Old 06-16-2017, 11:15 AM
SparkyF250's Avatar
Garage
Sorry @F100stroke I thought @h0trod would have chimed in. He's built a couple 6 doors and has quite a bit of custom fab experience.
F100stroke likes this.
Sparky
post #45 of 60 Old 06-16-2017, 11:29 AM Thread Starter
Quoted: 4 Post(s)
Oh no problem man, I will be using the fuel tank out of an expedition, since it has the same dimensions except that it is shorter, so I will experiment with one of those for now, thanks for the help though.
post #46 of 60 Old 06-16-2017, 11:34 AM Thread Starter
Quoted: 4 Post(s)
Expedition fuel tank
It has the same fuel float sending unit diameter
post #47 of 60 Old 06-16-2017, 01:24 PM
SparkyF250's Avatar
Garage
Great, hope it works out. Keep the pics coming, this is one of the coolest builds on here in awhile.
Sparky
post #48 of 60 Old 07-15-2017, 09:18 PM
Machinist & Fabricator
h0trod's Avatar
Quoted: 58 Post(s)
Garage
how far did you get with this bud?
I found 5/16 and 3/8 compression to -6AN fittings from Earl.
I also found quick disconnect to -6 AN for the sending unit.
sorry im a day late and a dollar short,
but heres how I did my fuel lines, post # 89
https://www.powerstroke.org/forum/99-...bed-drw-9.html
2001 F350 CCC SB DRW
1998 E350 7.3 clubwagoon
94 F25Bronco
87 F350 6door 94 7.3 IDIT moose motivated ZF5
63 MANchero 97 7.3 on a 89 F350 frame
1945M-37 IDI/ZF5 2WD
1941 1/2 ton pick up in the planning stages
many gassers, irrelevant here
h0trod is offline
post #49 of 60 Old 07-22-2017, 04:36 PM Thread Starter
Quoted: 4 Post(s)
Finally after 35 days of training in the desert, I'm finally home and ready to work on this thing, and im in luck, i found a fuel tank out of a 2014 f250 diesel and this thing fits right where the old one used to go, it surprises me that the 2014 has such a small fuel tank, only 26 gallons and it is about a foot and half shorter than the 38 gallon tank I originally had, so now i can get back in to it.
Rattlesnake18 and SparkyF250 like this.
post #50 of 60 Old 07-22-2017, 05:13 PM
SparkyF250's Avatar
Garage
I wondered where ya been. Training? military? If so go to the User CP (upper right) and then to Group Memberships and request to join the Military Member group.
Looking forward to seeing that project running, keep at it.
Sparky
