2008 6.4 wiring issue ?? I think - Ford Powerstroke Diesel Forum
Powerstroke Forum Polls Vote here!
 1Likes
post #1 of 8 Old 05-31-2019, 06:10 AM Thread Starter
I purchased this 2008 F350 at auction and it has been a great truck for the most part
when I purchased it the dash gauges would act up by the gauges going out and the message center would light up like a Christmas tree. Sent the gauge cluster in for repairs and they fixed it and all was great until 3 weeks ago
the dash is doing the same thing again so I sent it back for repairs and they said it fine. !!
I checked all of the grounds and added additional grounds to be sure but no fix.
It starts and runs just fine for miles then the dash will light up and gauges die for 5 to 15 min then it returns to normal. the truck always runs great both ways. but if I shut down the truck with the dash acting up the pat's locks me out. I need to disconnect the batteries for about 30 min then it will reset and start.
I have had it in the shop for two week with them trying to find the issue with no luck, They replaced the Dash cluster connector saying some pins were bad ?? but no luck it did it again.
they are claiming that it is my H&S tuner. but when I talked to the H&S guys they say it is not and cant do that, I even spoke with SCV tuner think of replacing it and they said don't waste your money it not the tuner, they could have just sold me one for the sale but good guys
I am at a loss of where to look next any ideas
post #2 of 8 Old 05-31-2019, 06:13 AM Thread Starter
Error codes
ICM no communication
PCM no communication
Air Bag
Breaks
Traction control
Had it tested at a ford shop and all checked out fine throws the same codes every time
post #3 of 8 Old 05-31-2019, 06:17 AM
djmaguire's Avatar
Quoted: 1568 Post(s)
Garage
Please post the actual numeric codes. Thanks.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #4 of 8 Old 05-31-2019, 06:28 AM Thread Starter
PO578
UO151
UO155
for the engine
and no new transmission codes at this time
[email protected]omcast.net is offline
post #5 of 8 Old 05-31-2019, 07:00 AM
djmaguire's Avatar
Garage
It's interesting that P0578 does not appear in the PC/ED.
So... the other two are:
...and:
Given U0155, it is not surprising that you are having cluster issues. Both codes refer to the Workshop Manual section 418-00. The files comprising that section are attached.
2004 F550 CC Lariat
post #6 of 8 Old 05-31-2019, 10:43 AM Thread Starter
Wow your are the best
I will print and give these to my repair shop I know they have the ford tool to do all this
and lets hope they can find the glitch
thanks
post #7 of 8 Old 05-31-2019, 10:44 AM
jman37's Avatar
Quoted: 294 Post(s)
Garage
If they have IDS they would have all of this...
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's
'88 Mustang LX - Built 306ci, built AOD, 4.10's
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is online now
post #8 of 8 Old 06-20-2019, 04:27 AM Thread Starter
Wiring issue solved
I thought I would finish this off as we have found the issue and man do I feel stupid and the shop that charged me 2000.00 should as well.
If you have an issue with Ford Super duty's Check the OBD plug, !! the retaining clips that hold the pins in place dry out and or Break causing the pins to misalign and touch each other or not make proper contact with OBD reader
All fixed $18.00 Amazon
djmaguire likes this.
