PCM/HEX code interchangeabilty - Page 3 - Ford Powerstroke Diesel Forum
 7Likes
post #21 of 24 Old 12-13-2017, 12:20 PM
Quoted: 176 Post(s)
Originally Posted by JustinOOO9 View Post
FHP2-Hydra told me to run vjae3ke or vjae3k3 (something like that) but the shifts were very soft with a lot of slipping.
its a 99.5 Cali truck but with the federal glow plug system, automatic,
I was just hoping to get FHP2 tunes with much firmer and quicker shifts. The only thing that was odd with the vraa6s3 was it seemed to lock the torq super early causing the truck to bog down and it sounded like I was in tow/haul mode all the time.
I would love to get this resolved because I can't shift on the fly lol... Ive been using vraa6s3 files from bill which I love but I have to turn the truck off, then key on/engine off to change tunes.
I have a revised VJAE3K3_140x file for you. I just need to know your email address so I can send it over.
If this file works to solve your sloppy shifts, I will apply the changes across to the remainder of the cal list to get you taken care of
Dylpickles likes this.
Chatham036 is offline
The Following 2 Users Say Thank You to Chatham036 For This Useful Post:
JustinOOO9 (12-13-2017)
post #22 of 24 Old 12-13-2017, 12:23 PM
Quoted: 176 Post(s)
Disregard. I found an email chain from back in March I just replied to with your file attached.
post #23 of 24 Old 12-13-2017, 01:09 PM Thread Starter
JustinOOO9's Avatar
Quoted: 1706 Post(s)
Garage
Feedback Score: 3 reviews
Thank you very much. I can't tell you how much I appreciate the help. I will be able to load the tune on this Saturday and take it for about a 45 mile test drive. I'll send you an email letting you know asap.
Chatham036 likes this.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is online now
The Following 2 Users Say Thank You to JustinOOO9 For This Useful Post:
Chatham036 (12-13-2017)
post #24 of 24 Old 12-13-2017, 01:20 PM
00t444e's Avatar
Quoted: 622 Post(s)
As long as all the calibrations are the same hex code you should be able to switch them on fly without any issues regardless of what your original pcm code is. Mine has no issues shifting on the fly and my hex codes are different from the factory code.
00 f250 ext. cab, lb, 4x4, 170,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, KC 300x 63/73/.84 turbo, PHP Hydra, Riff Raff frx,, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, Edge CS2, 4 in diamod eye straight pipe 6 in tip.
00t444e is online now
