1983 CJ7 Gears - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By mattastic13
  • 1 Post By 2MANYPROJ3CTS
post #1 of 5 Old 03-23-2018, 12:16 PM Thread Starter
mattastic13's Avatar
Quoted: 16 Post(s)
1983 CJ7 Gears
Alright guys, since this is a much friendlier forum, I figured I'd ask here.
I am rebuilding my 1983 CJ7. It has a 5.0L Ford V8, A T177 Jeep 4spd tranny mated to a Dana 300. It will also have a 14bolt rear end and a Dana 60 front. I'd like to run 40" tires.
I've been looking at 5.38 gears, but don't know if those will be too deep.
Any thoughts?
2012 F250 King Ranch 4x4
Ready Lift 1.5" level kit front/Custom 1" block rear/Fox 2.0s/Nitto Trail Graps 295/65/R20 on stock King Ranch rims No Limit delete pipe with Gearhead tunes on a SCTx4, EGR block off plates
No Limit Stage 2 Intake
Sweet Gipsy Danger Sticker
mattastic13 is offline
post #2 of 5 Old 03-23-2018, 02:02 PM
lonestarcj7's Avatar
I am running 4.56's with 40's and Dana 60's. I wish I was a closer to 5.38's. I typically turn off the OD running highway speeds just because it boggs the Jeep down. Jeep LJ with 4 speed auto tranny. My guess is you will be fine, especially with the 5.0.
2017 F-350 SRW Platinum Crew Cab FX4 Short Wheel Base
lonestarcj7 is offline
post #3 of 5 Old 03-29-2018, 10:14 AM
2MANYPROJ3CTS's Avatar
Quoted: 18 Post(s)
Garage
Any thoughts?
Check out the grimmjeeper gear ratio calculator. Just google it. it will allow you to compare different gear sets with drivetrain/tire combos. I use it all the time. awesome tool.
T-17X series trans are solid transmissions but in my opinion are geared a little tall & making a differential gear change more desirable. That's why I ditched my T-176 and adapted in the Ford NP435 (wide ratio) to the D300. In doing so, I was able to run tall gears for the highway and have plenty of bottom end for the trails... 71:1. Pretty good for no doubler or 4:1 kit and just some stock junkyard **** I rebuilt and bolted together. This was with 4.10's and 37's. I was only running built Waggy D44's.
I'd think about what your end goal its. Wheeler/DD (mine was) or trailer queen that rarely sees pavement.
I loved being able to stay under 2500 RPMS and go 70mph with no issues and still have great crawling gears.
I'd be looking at 5.13's. you'll have plenty of power to push it without dogging it. You'd be hitting 3000Rpms at 70mph in 4th gear (1:1).
The 2.61:1 reduction of the D300 (stock) without a 4:1 kit would get you about a 51:1 final drive in 1st/ 4Lo.
With a 4:1 kit, your looking at a 78:1 1st gear/4Lo final drive. Pretty good bang for your buck.
4.88's are another option but are going to feel a little tall in the lower gears on the street.
Semper Fi
Daddy's truck- '02 F250/7.3/6spd/4x4/6"lift/35's/Procomp traction bars/K&N intake/4" Banks turbo-back/aftermarket turbo/Hydra
Momma's truck- 01 Excursion/7.3/Auto/4x4/AFE stg 2 intake/walker Big Truck Muffler/BD Thruster II turbo/ TS6 /295x70's/F350 springs
2MANYPROJ3CTS is offline
The Following User Says Thank You to 2MANYPROJ3CTS For This Useful Post:
mattastic13 (03-29-2018)
post #4 of 5 Old 03-29-2018, 05:06 PM Thread Starter
Quoted: 16 Post(s)
Awesome!
Thanks guys!
2MANYPROJ3CTS likes this.
post #5 of 5 Old 03-30-2018, 10:24 AM
Quoted: 18 Post(s)
Garage
no prob brother. I'm super nerdy about old jeeps. Just sold my 86 CJ7 a couple months ago. I miss it bad but we outgrew it. I'll probably go back to an FSJ in the future.
mattastic13 likes this.
Semper Fi
