Intro. No start 6.0 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-08-2019, 12:22 PM Thread Starter
JoeyJ's Avatar
Quoted: 12 Post(s)
Intro. No start 6.0
’m new to the forum and I’m hoping someone can help me. Two diesel mechanics cannot figure it out. I have 2006 King Ranch with 168,000. Very rough start after numerous cranks two weeks ago. Ran very rough when it finally started but smoother out within 200 yards. Parked it and it never started again. 2- New batteries after one failed test. Replaced alternator to 130V. Replaced starter to 6.7 starter. Two new fuel filters and old ones looked fine. FICM sync yes. FICM module swapped and no difference. Oil pressure excellent. RPM on start excellent. Wiring harness checked and rechecked and wiggled. Fuel filter bowl shows no bubbles when turning motor with stand pipe removed and fills quickly with fuel. No codes except crankshaft sensor after prolonged starting attempts. Pulled each fuel injector connection and it throws a code for each of the 8 injectors. Everything shows it should start, but only cylinder 1 fires. Any help would be much appreciated!
JoeyJ is offline
post #2 of 3 Old 12-08-2019, 01:13 PM
ChrisSki's Avatar
Quoted: 588 Post(s)
Welcome. This also seems to be posted in the 6.0 section.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #3 of 3 Old 12-08-2019, 01:16 PM Thread Starter
JoeyJ's Avatar
Quoted: 12 Post(s)
Yes. I saw that I should post it in the Introduction rather than the prior, but I don’t know how to erase the duplicate.
JoeyJ is offline
