Torque App Photos - Page 71 - Ford Powerstroke Diesel Forum
 16Likes
post #701 of 717 Old 03-05-2018, 08:58 AM
Quoted: 9 Post(s)
Originally Posted by AgTires4295 View Post
I'd consider uninstalling and deleting everything. Start from the bottom and reinstall everything. I've never heard of a problem like this (especially from an '02).
last night I uninstalled torque pro and reinstalled it and it didn't change anything.
It is doing this on my my Samsung Galaxy S 7 as well as my Pumpkin android radio
Sent from my SM-G930T using Tapatalk
futurerider103 is offline
post #702 of 717 Old 03-05-2018, 10:37 AM
Quoted: 17 Post(s)
have been using TorquePro for about a year now and love it. I've even convinced my wife to use the tablet and run torque pro when she's driving the truck!
Problem is, she doesn't really know what numbers are "good" and what are "bad". I've tried adjusting gauge min and max to reflect it, but she doesn't think that way. So, I was wondering if it was possible to add a "red zone" to the gauges where it's appropriate? I use a standard gauge setup but would like to add a curved red bar where the indicator dashes are. Is this possible? I've attached picture of current setup.
AgTires4295 likes this.
'66 Mustang GT -- '67 F100 Step-side -- '03 F550 Super Duty -- '12 Mustang GT -- '16 Fusion Titanium
Nothing stock about any of them, except the Fusion.
pass1over is offline
post #703 of 717 Old 03-05-2018, 11:32 AM Thread Starter
Behavior Modificationist
AgTires4295's Avatar
Quoted: 32 Post(s)
Without me playing with my programming to see specifically about curved red bars, I have parameters that are set to blink when approaching the "red zone". It's in the options as you select your gauge. Whenever those temp gauges start to get a little high, I know to back off as the blinking numbers catch my eye while driving.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #704 of 717 Old 03-05-2018, 11:34 AM Thread Starter
Quoted: 32 Post(s)
You've got me stumped at the moment and I won't be to my 7.3 until the weekend. As a fail-safe, have you read the initial pages of the thread to ensure you're set up properly?
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #705 of 717 Old 03-07-2018, 03:50 PM
Quoted: 9 Post(s)
ok I just master reset the radio, pre-installed Torque Pro, all the ford pids show up but the oil temp still doesn't go over 86.5F. There aren't any CEL bit I wonder if the oil temp sensor is bad. I don't have a scanner that reads oil temp.
post #706 of 717 Old 03-07-2018, 03:56 PM
Quoted: 9 Post(s)
Okay I know what I did wrong. When I originally went in to manage custom kids and I selected engine oil temp the unit type by default was set to Celsius and I change that to Fahrenheit so when I look at the difference in temperature I thought maybe if I change that back to Celsius it will fix the problem and it did
post #707 of 717 Old 08-10-2018, 07:27 PM
Quoted: 60 Post(s)
Are you able to monitor all three exhaust gas temp sensors? Or is it necessary to monitor all three? I haven't paid for the pro torque app yet, just been using the free one that doesn't have EGT. Being new to diesels I'm not sure what exactly I should be looking at (what's most important?). I imagine coolant, oil, and transmission temps, as well as exhaust temps. Fuel pressure too?
I've used torque for years on my other vehicles...but trying to get a permanent tablet setup for the diesel now!
onecrazyfoo4u is offline
post #708 of 717 Old 08-11-2018, 02:42 PM
Island Dweller
Qholic's Avatar
Quoted: 87 Post(s)
There are no exhaust gas temp sensors and you cannot monitor EGT with Torque with a Bluetooth adapter. You also cannot monitor fuel pressure. You can monitor most other temperatures, boost, VGT, IPR, voltage, FICM, exhaust back pressure and a bunch more.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, TSD tunes, Blue Spring, Warren 155/30 injectors, KC Turbos Stage 2, IPResearch Oil Cooler Relocation, IPResearch EGR delete, IPResearch Gen 2 Coolant Filter, Magnaflow Dual Tip 5", Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #709 of 717 Old 08-11-2018, 03:52 PM
Quoted: 60 Post(s)
Oh well that's lame. I thought EGT was one of the critical things to monitor on diesels? What is VGT and IPR? How do you monitor EGT then? Have to get a separate tuner program to monitor?
post #710 of 717 Old 08-12-2018, 09:25 AM
Island Dweller
Qholic's Avatar
Quoted: 87 Post(s)
Well, it is not lame if you consider that you can monitor a ton of stuff for $5 plus Bluetooth OBD dongle. EGT is critical if you are towing or running hard. I monitor EGT using my Livewire and use a splitter so that I can run it and Torque simultaneously. If you do not want to do that there many gauge setups that you can install.
IPR= Injector Pressure Regulator
VGT = Variable Geometry Turbo or how much the vanes are opening or closing
The picture is what I monitor using Torque
Shawn
Qholic is offline
