Is the 6.0 deleted? - Ford Powerstroke Diesel Forum
 3Likes
  • 2 Post By jokester00
  • 1 Post By jokester00
post #1 of 4 Old 01-18-2020, 11:04 AM Thread Starter
Is the 6.0 deleted?
My boss's service truck is an early 04 F350 single wheel truck with a 6.0 and I was told by a friend that it has been deleted. How do I tell? I took some pictures of where I think the EGR cooler would have been but I don't see it there. I'll post the pictures so maybe someone can help. Egr valve is still there, but as far as I can tell the cooler is not, but maybe I missed it because I've never looked at a 6.0 before now
ID:	727269   Click image for larger version
NebraskaGMC is offline
post #2 of 4 Old 01-18-2020, 11:16 AM
jokester00's Avatar
Quoted: 530 Post(s)
Garage
You are correct - the EGR cooler has been deleted. The "J" shaped tube in your 2nd picture confirms it.
On a side note - that is not an OEM oil filter cap. You need to get one from a Ford dealer and make sure you put an OEM filter in there. if not, the system won't function as intended, and you will end up having issues down the road.
-jokester
ZMANN and nine9six like this.
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #3 of 4 Old 01-18-2020, 02:18 PM Thread Starter
-jokester
Thank you for confirming that this truck is in fact deleted. What sort of problems will the current oil filter cause? As far as i know its been run with this type of filter since he bought the truck when it had 120k miles on it. It now has almost 270k
post #4 of 4 Old 01-18-2020, 04:39 PM
jokester00's Avatar
Quoted: 530 Post(s)
Garage
Enjoy
-jokester
nine9six likes this.
Edge EAS EGT probe
