Blackstone oil comparison for Rotella T vs T6, and Amsoil (soon) - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By The Evil Twin
post #1 of 7 Old 12-21-2019, 08:35 AM Thread Starter
carlspeed's Avatar
Quoted: 6 Post(s)
Hello,
I've been involved in engine stuff, whether it be with bikes, cars, atvs, etc since I was a child. I'm sure that you know, one of the most intensely discussed topics is oil. Instead of going through theory of oil use and such, I'm testing them. I figured I'll run a few different oils through my truck using an 8k mile OCI, and compare them. This way, in 5-10 years when I get a newer diesel, I'll know which oil is the absolute best and can use that exclusively. My truck has almost 270k on it. It's entire life it has ran on standard Rotella T. Since I heard that they changed their formula, I put into motion my test, and switched to T6, planning on using that anyway. I'm an Amsoil dealer, and when I finished the OCI on T6, I switched to Amsoil Signature Diesel. Another 10 months or so and I'll be able to show data for that. In this chart, you will notice that the last time I had T in the engine, I had 3 qts I had to fill. I think that was a bit of an exaggeration, I think I only really used 2. That is also partially because I overfilled it slightly, and I think some of the oil burned off. But still, that's a quart more than with T6. Curious to see how Amsoil does, and if anyone has suggestions for the next oil to test out. Hope this helps some of you.
Another fun tip of this report, is that it shows me using longer OCIs for oil when using the old Rotella T formula. 4.5k to 6.5k, and finally to 8k. Absolutely no reason not to run 8k, and I would believe that's with any decent diesel motor oil. Happy holidays! I'm subscribed to this thread so I'll get notifications if there are any questions. Otherwise I'll post back up in 10 months or so when it's time for another fill.
Name:	blackstone t6vst.jpg
'01 F350 7.3l SRW CC 4x4 Lariat
carlspeed is offline
post #2 of 7 Old 12-21-2019, 11:28 AM
6riders's Avatar
Quoted: 16 Post(s)
How much does oil analysis cost and how often do you have it done?
Sent from my Vivo XI PLUS using Tapatalk
6riders is offline
post #3 of 7 Old 12-21-2019, 01:49 PM Thread Starter
carlspeed's Avatar
Quoted: 6 Post(s)
It isn't that bad, I think it's just under $40 with the tbn which tells you how long the oil could've gone. I do it every 30k-40k on most cars. With the truck because I'm testing stuff, I'm doing it more often. With wife's car it's about every 4 7k oil changes. I use Supertech synthetic in her's. Been fantastic for the last 40k.
The Following User Says Thank You to carlspeed For This Useful Post:
6riders (12-21-2019)
post #4 of 7 Old 12-22-2019, 05:23 AM
The Evil Twin's Avatar
Quoted: 176 Post(s)
Funny you post this. I'm nearing my 2nd OCI with AMSOIL 5w40. After that, I was going to send a sample in. There is so much residual oil left in these motors that running one crank full after the 10w30 would not give true results IMO.
carlspeed likes this.
2015 Oil Burner
CCLB Lariat Ultimate, 10k, Plow Package.
Mods have begun: 2wd Valance, Bully Dog GT, smoked lenses
The Evil Twin is offline
post #5 of 7 Old 12-23-2019, 07:50 AM
Quoted: 96 Post(s)
So I don't know what to look for with these numbers...what does it tell the difference is between T and T6? Is there any advantage to run the T6 according to the oil analysis?
onecrazyfoo4u is offline
post #6 of 7 Old 01-03-2020, 05:12 AM Thread Starter
carlspeed's Avatar
Quoted: 6 Post(s)
In my opinion, no. These numbers are extremely close. My only concern would be that I have heard Rotella T has changed to Rotella T5, and it is no longer as good of an oil. It's also no longer recommended for motorcycle purposes like the old T was. I'm sure the oil is fine, and they simply added some type of additive that is not good for old diesel motors or motorcycles. I'm not sure, but the $5-$10 more for a gallon of T6 will be what I do in the future.
That makes sense, I didn't think of that. I guess I'll do the Amsoil sample, and then do one more sample afterward. You think that would be reasonable enough?
post #7 of 7 Old 01-03-2020, 05:50 AM
Quoted: 176 Post(s)
As long as the viscosity was the same, I would think so. I went from 10-30 (used that because I was only towing <5000 pounds less than 3k a year) to the 5-40. Not sure how much oil these motors hide but I figured a sample would be diluted enough to skew the results. Like tasting wine or bourbon, always use a new glass!
2015 Oil Burner
