Behind dash - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 12 Old 11-27-2019, 08:26 AM Thread Starter
Quoted: 2 Post(s)
Behind dash
What is right behind the dashboard below the vent on right side of steering wheel
Coyoteman5 is offline
post #2 of 12 Old 11-27-2019, 08:33 AM
Spirit's Avatar
Quoted: 23 Post(s)
Ford's top-secret guide to understanding the 6.0?
Spirit is offline
post #3 of 12 Old 11-27-2019, 08:50 AM
It is What IT is
Quoted: 436 Post(s)
Wires, plugs, voids, insulation.....Pull the panel, let us know......
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
zsargent is offline
post #4 of 12 Old 11-27-2019, 09:15 AM Thread Starter
Quoted: 2 Post(s)
Not much help fellas
post #5 of 12 Old 11-27-2019, 09:35 AM
Spirit's Avatar
Quoted: 23 Post(s)
I think that area is where the 4x4 selector is located on the equipped models. May be some rough-in wiring, etc. behind the panel at this area? Googling "behind dash' along with your year & model produces some info which may be helpful to you.
Spirit is offline
post #6 of 12 Old 11-27-2019, 10:03 AM Thread Starter
Quoted: 2 Post(s)
Thanks will do
post #7 of 12 Old 11-29-2019, 12:36 AM
Can't find information on what's behind it even when I search "behind dash"
speedvent is offline
post #8 of 12 Old 11-30-2019, 11:08 PM
Quoted: 40 Post(s)
Mine was an 02 2 WD and there was nothing. I actually mounted my XM Receiver screen in that location back when they were a stand-alone unit.
Tom
2014 XLT Premium CC Dually 2WD, Remote Start Added, Diesel Site Dual Filters, Rudy's Cold Air Pipe, Infotainment Radio Swap + Rear Camera Added
2002 XLT CC Dually 2WD, 6 Spd, True Workhorse that kept going.
1999 F250 Lariat CC LB SRW 2 WD, Automatic. Just didn't perform towing.
tomshep is offline
post #9 of 12 Old 12-01-2019, 10:32 AM
SuperCrutyPS's Avatar
Quoted: 649 Post(s)
Garage
Not trying to be smart### here, but is there a panel below the steering wheel? If so, pull that and look up in there. Use a mirror and flashlight, if necessary.
I'm guessing you want to mount something there? If so, you'll want to KNOW what's there before you drill so can move anything in the way.
Just my thoughts.
PSD Interceptor likes this.
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB |
5th Wheel |
Proud US Navy Veteran | '76-'80 -
- 'Gator Navy
SuperCrutyPS is offline
post #10 of 12 Old 12-01-2019, 10:48 AM
ChrisSki's Avatar
Quoted: 588 Post(s)
I have a 4 WD King Ranch and it has the 4 WD switch there. The little recess below where you're pointing is where the OEM tow controller would go, and my 4 upfitter switches are installed to the left of the controller. If I took all that out, there'd be nothing back there. Not sure if that is the case for you though.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
