Little rust spots on cab. Hidden by door repair? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-14-2019, 01:14 PM Thread Starter
Quoted: 11 Post(s)
I have a 2014 f250 crew cab. On the bottom of our doors are round rubber dampeners/bushings... Where these impact the cab, I've developed a little amount of surface rust.
How would you guys recommend treating this? I was thinking a wire brush... Some rust inhibitor... Primer and touch up paint. It's a hidden area. I don't care if it's perfect.
Any thoughts?
travsav is offline
post #2 of 6 Old 11-14-2019, 01:23 PM
UR2EZ's Avatar
Quoted: 69 Post(s)
Any thoughts?
What you said is perfect
Sent from my SM-G975U using Tapatalk
UR2EZ is offline
post #3 of 6 Old 11-14-2019, 01:43 PM Thread Starter
Quoted: 11 Post(s)
Awesome thanks a lot!
travsav is offline
post #4 of 6 Old 11-14-2019, 01:49 PM
UR2EZ's Avatar
Quoted: 69 Post(s)
You're very welcome
UR2EZ is offline
post #5 of 6 Old 11-20-2019, 02:01 AM
What I do is I tape the unaffected areas first and use a rust remover, just follow the instructions written, then use sandpaper just to polish. Lastly, add primer and the paint.
speedvent is offline
post #6 of 6 Old 11-23-2019, 10:12 PM
Quoted: 40 Post(s)
I need to check mine.
After your repair I would add some clear tape film in those areas to avoid it in the future.
Tom
2014 XLT Premium CC Dually 2WD, Remote Start Added, Diesel Site Dual Filters, Rudy's Cold Air Pipe, Infotainment Radio Swap + Rear Camera Added
2002 XLT CC Dually 2WD, 6 Spd, True Workhorse that kept going.
1999 F250 Lariat CC LB SRW 2 WD, Automatic. Just didn't perform towing.
tomshep is offline
