Oh look! Another additive thread. - Page 4 - Ford Powerstroke Diesel Forum
 16Likes
post #31 of 37 Old 11-10-2019, 06:58 PM
Loud Exhaust Aficionado
Timbo_Slice's Avatar
Quoted: 67 Post(s)
Garage
I like Project Farm. My favorite video is when he ran Bacon Grease as oil in the lawnmower.
'15 F350 6.7L Super Crew Cab 4wd, 37 13.50 R20 Nitto Trail Grapplers on 20x12 TIS 535b -44 offset
Front - PMF 4-link 6 inch lift
Rear - PMF 2.5 Lift from Rear Shackle Hanger Flip Kit
- No name 5" rear block
Baja Customs Tracinator tracbar
AMDP pass through egr plate
AMDP Billet aluminum Y pipe intake
SCT TS+ Livewire
Full EGR, DPF, CCV delete
5" MBRP downpipe back straight pipe
Rigid D2 fog lights, 20" Opt7 light bar
Mag-Hytech high capacity lower oil pan
Mag-Hytech high capacity transmission pan
Redhead Steering Gear Box, Helwig sway bars
Eventually I'll get around to the JL Audio 13w2 install
Timbo_Slice is offline
post #32 of 37 Old 11-13-2019, 11:39 AM
JJMassar's Avatar
Quoted: 15 Post(s)
Garage
I would like to see this guy test out the actual Motorcraft Diesel Fuel Additive. I have tried a lot of the additives out there and the Motorcraft one actually produces the best MPG of all that I have tried. Needless to say, that's the one I now use in every tank.
JJMassar is offline
post #33 of 37 Old 11-13-2019, 12:03 PM
Quoted: 93 Post(s)
Interesting...I've never tried the Motorcraft. It costs almost twice as much as Diesel Kleen (about $1.5 per tank for me; Motorcraft would be $2.7 per tank). Wonder if it makes up for it with the mpg difference?
onecrazyfoo4u is offline
post #34 of 37 Old 11-13-2019, 12:15 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 920 Post(s)
Feedback Score: 3 reviews
That would be like adding a gallon of fuel for me at 16+ miles per gallon. But that's not the reason people need to use additives.....it's to lubricate the HPFP to a point to prevent a failure due to poor lubrication.
If an additive supplied the proper lubrication to prevent the HPFP failure as long as you use it, but gave NO other benefits would you use it???
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #35 of 37 Old 11-13-2019, 12:30 PM
Quoted: 93 Post(s)
Most definitely, and that's why I use them. The added mpg is just a side bonus. It would be nice to see the motorcraft fluid tested to see if it provided any better lubrication than the ones that scored the highest.
post #36 of 37 Old 11-13-2019, 04:19 PM
Quoted: 467 Post(s)
Garage
Would have been a more comparable - meaningful test, if he would have used diesel mixed with the recommended amount of each additive -- running straight additive does not allow for the chemical action the fuel mix provides
Like to see the test ran again -- would the results be different?
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #37 of 37 Old 11-13-2019, 06:59 PM Thread Starter
Drunk Post Extraordinair
Old King Coal's Avatar
Quoted: 231 Post(s)
Garage
I doubt it. If you haven't read the study posted a couple pages back it's really worth the read. They treated the fuel as per the instructions ans sent the samples to a real deal lab for testing. Howe's didn't do good there either.
So strong is Tradition that later generations will dream of what they have never seen.
Old King Coal is offline
