2003 6.0l no hot start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-22-2019, 10:27 AM Thread Starter
2003 6.0l bulletproffed powerstroke. No hot start, replaced ipr and icp, looking for other solutions that hopefully aren't very invasive. Has also had a HPOP recently. Builds oil pressure when cranking on cold start and will start(obviously), doesn't show oil pressure building when cranking when hot. Bad lPOP possibly?
POS03stroker is offline
post #2 of 5 Old 09-22-2019, 11:10 AM
Quoted: 368 Post(s)
Garage
Need to get a gauge on there to be sure, the oil sender is just a switch(7psi) -- so the oil gauge is basically a glorified idiot light
You could pull the pressure regulator and check to see if the piston moves freely(near the crank pulley)
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 5 Old 09-22-2019, 11:22 AM Thread Starter
Also to add that I pulled the oil filter and cranked on it and the filter reservoir does fill when cranking if that makes a difference
post #4 of 5 Old 09-22-2019, 12:01 PM Thread Starter
And would that oil pump valve piston cause only hot start failure?
post #5 of 5 Old 09-24-2019, 07:41 PM
If it start fine cold but doesn’t when hot this usually ends up being a leak somewhere in hpoil system. Run an air test.
Sonoma6Leaker is offline
