2014 6.7 stock truck making black smoke - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-20-2019, 10:35 AM Thread Starter
I have a 2014 f350 platinum (just stating so options are known) that I bought used @ about 150K mi. This is my second 6.7 powerstroke and I deleted my other one myself at about 70K mi so I'm familiar with the truck fairly well. My problem is my current truck is stock with EGR and DPF all in place, no tuning that I am aware of, yet it is making black smoke at reasonable throttle percentages in any gear and in any situation, not just from stop to go. It recently has thrown codes P2A01 and P207F. It also seems to make somewhat poor fuel economy IMO (about 16avg on highway). The truck runs like a top, shows absolutely no signs of injector or turbo issues of any sort and has power like crazy just makes smoke through the DPF. My other concern is I have driven the truck for approaching 3K mi now and only seen it regen one time and it lasted for about 3min and never throttled up to 2K at all, just idled. I intended to delete the truck when I bought it, and am about ready to order some parts to do so but I dont want to delete DPF and EGR and find out theres an electrical issue of some sort after that.
Any ideas from anyone??
I do currently have a OBD scanner so I can throw some numbers from sensors out too if anyone can tell me what some standards are to compare with.
Also unrelated (hopefully): the steering wheel controls for radio and such mostly dont work, in other words some buttons do nothing, some perform an incorrect function, and some do nothing at all. I figured this was due to the switches getting wet at some point or something and have not swapped anything yet to see if it fixes anything.
Anything helps, thanks!
Teejay1324 is offline
post #2 of 13 Old 07-21-2019, 10:49 AM
Master_Chase's Avatar
Quoted: 516 Post(s)
I'm not an expert in 6.7s but I'm pretty sure 99% diesel soot doesn't make it the DPF and since you said the regen only lasted for 3 minutes I'm thinking there might be a hole punched through the DPF
E̶a̶r̶l̶y̶ ̶2̶0̶0̶3̶ ̶6̶.̶0̶ ̶E̶x̶c̶u̶r̶s̶i̶o̶n̶ ̶f̶u̶l̶l̶y̶ ̶b̶u̶l̶l̶e̶t̶p̶r̶o̶o̶f̶e̶d̶,̶ ̶1̶5̶5̶/̶3̶0̶ ̶i̶n̶j̶e̶c̶t̶o̶r̶s̶,̶ ̶K̶C̶ ̶S̶t̶a̶g̶e̶ ̶2̶,̶ ̶a̶n̶d̶ ̶a̶ ̶l̶o̶t̶ ̶o̶f̶ ̶o̶t̶h̶e̶r̶ ̶s̶t̶u̶f̶f̶.̶ Cummins swap in progress. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #3 of 13 Old 07-21-2019, 05:00 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 593 Post(s)
Feedback Score: 11 reviews
Start with your codes and get to work.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #4 of 13 Old 07-22-2019, 03:52 PM
Miamipowerdiesel's Avatar
Quoted: 2 Post(s)
Garage
what codes come up? did you check the charge pipe for any cracks ? and weird noises?
Miamipowerdiesel is offline
post #5 of 13 Old 07-23-2019, 04:22 AM Thread Starter
Codes: P2A01 and P207F
And yes I have looked for boost leaks and tested a few ways and have found no sign of any.
post #6 of 13 Old 07-23-2019, 06:51 AM
As far as the steering wheel control issues go, my 2011 started doing that a while ago. Turn the volume up, channel changed, turn the volume down, volume went up, all sorts of weird stuff. I ordered a new steering wheel switch for about $50, replaced and it worked fine for a while. Started having that issue along with all sorts of other electrical issues. Wipers wouldn't shut off, interior lights wouldn't come on when you opened the doors, steering wheel radio controls started acting up again. Replaced the ECM, reprogrammed and all has been fine since.
Noel04z06 is offline
post #7 of 13 Old 07-23-2019, 07:06 AM
Quoted: 2 Post(s)
Garage
does it make any boost?
post #8 of 13 Old 07-23-2019, 10:13 AM Thread Starter
I havent had any other issues so far except basically exactly what you said there. Did you have Ford reflash the ECM? How much was it to do that?
post #9 of 13 Old 07-23-2019, 10:18 AM Thread Starter
Yep boost is normal, builds and holds and also tops at about 22psi like normal. Like I said nothing seems weird with the performance at all except for the black smoke. Do you know exactly what these trucks reference for fuel injection? Looks to me like maybe a combo of MAF and NoX/o2? My thinking is the reference point for fuel injection as well as filter regen is not reading correctly or at all which should be eliminated by deleting the bull**** (I would think). But if the engine is referencing the hot side NoX sensor in the down pipe, that will still be there and I'm worried may still be way over-fueling. Not having much luck finding information about the 6.7 platforms references as far as injection goes on the internet
post #10 of 13 Old 07-23-2019, 10:27 AM
Quoted: 2 Post(s)
Garage
did u check the air filter?
