Remote countdown timer for block heater? - Page 3 - Ford Powerstroke Diesel Forum
 12Likes
post #21 of 33 Old 01-03-2019, 01:56 PM
7.3lf550's Avatar
Quoted: 91 Post(s)
Originally Posted by Ralphie9 View Post
Ok am I missing something here? At night I just plug mine into an extension cord running out from the garage. Been doing that for years without an issue...
I do the same thing. if i work 10 hours the truck is plugged in the other 14hours of the day. However its very inefficient energy wise. These guys are trying to save power which i can understand. However my entire power bill for last month(nov 15-dec15) was only 109$. This includes natural gas and having the truck plugged in all night every night. I do not know what it costs to keep it plugged in but its not alot.
03 7.3l 550, FRx, 6637 mod, 4 inch turbo back, ccv delete, aih delete, HPx, Riffraffs OCR, Turbo-pyro-boost-coolant EV2 gauges, Bullydog GT tuner.
03 X 6.0 175/30 warren sticks, Livewire TS w/ warren tunes, Blue spring mod, atlas 40 ficm, 270amp dc power alt
Originally Posted by Heavy_GD View Post
goats lives matter.
7.3lf550 is offline
post #22 of 33 Old 01-03-2019, 02:00 PM
ZMANN's Avatar
Quoted: 4014 Post(s)
figure a kilowatt an hour check your local prices since most rate $ in kilowatt per hour it makes the math easy
my local is 7.3 per kWH
6.0 flush pdf
ZMANN is online now
post #23 of 33 Old 01-03-2019, 02:03 PM
ZMANN's Avatar
it may be a non issue but
i don't like to leave mine plugged in too long since the element is sitting in non moving and a limited volume of liquid
I do not want to cook the coolant in that area
6.0 flush pdf
ZMANN is online now
post #24 of 33 Old 01-03-2019, 03:24 PM Thread Starter
The Evil Twin's Avatar
Quoted: 172 Post(s)
For my use, it is not because of the cold so much as it is the short drives. We might see lows in the 20s and occasionally teens. I want the engine to get >180 before I get where I'm going. The trans will hit 160 easy but the engine struggles to get to 150 in a 15 mile drive.
That said, generally speaking any more than 4 hours on the heater is not doing anything. Even at sub 0*f most (if not all) manufacturers say 3-4 hours is enough. At least from what I've read. At a certain point the air will suck as much heat out as the heater is putting in.
I dont know about the PS so much, but generators block heaters move coolant by convection through the water jackets. If/ when they get hot enough, the T stats will open and warm coolant will flow to the radiator. Cool, dense coolant will make its way through the bottom hose towards the heater. Even if the stats do not open, they have a small hole on the flange that allows coolant to bypass the stats so the water pump doesn't cavitate in stagnant coolant. Pumps that cavitate too long dont last.
2015 Oil Burner
CCLB Lariat Ultimate, 10k, Plow Package.
Mods have begun: 2wd Valance, Bully Dog GT, smoked lenses
The Evil Twin is offline
post #25 of 33 Old 01-03-2019, 03:50 PM
ZMANN's Avatar
i have never experienced the block heater open a tstat at 190 heat the radiator coolant even when plugged in for a long time i get about 100* on the guage and it drops as soon as the t stat opens ( telling me the radiator coolant is ambient temp)
they do sell a nice circulating heater that goes inline with the radiator hose
IMO the motor is too big of a heat sink to get the whole system warmed up
I was more concerned about this when running coolant with silicate
6.0 flush pdf
ZMANN is online now
post #26 of 33 Old 01-03-2019, 06:42 PM Thread Starter
Quoted: 172 Post(s)
No, I don't see the stat opening on a truck either but it isnt an enclosed insulated engine bay. Still, the coolant isn't stagnant.
The 1000 watt heater is only enough to increase the temperature of 3412 pounds of water 1*f. Offhand I don't know the difference between metal and water but the engine is plenty big. Except for the concern over silicates, I don't think you could run the heater "too long" . I do think that after a few hours the engine rejects as much heat as you are adding.
2015 Oil Burner
post #27 of 33 Old 01-13-2019, 05:24 AM Thread Starter
Quoted: 172 Post(s)
Update.
At first I couldnt figure out why it was staying in so long. The countdown was far from accurate. I set it for 3 hours and it was still in after 4. Every time I looked at it in the app, it was still counting down but it was like it paused every so often. I still dont know why for sure, but I moved it to an outlet in the other side of the garage where it has a better Wi-Fi signal and it seems to work correctly. The far side of the garage had a 43% signal and the near side has a 63% signal. Maybe it uses internet time? Seems silly but today will ne the third day I've tested it in the new location.
2015 Oil Burner
The Following 4 Users Say Thank You to The Evil Twin For This Useful Post:
JustinOOO9 (01-16-2019), ZMANN (01-13-2019)
post #28 of 33 Old 01-16-2019, 04:30 PM
Fordracinjunkie's Avatar
Quoted: 8 Post(s)
I use a Kaza tp link app controlled switch. It will do count down, you can program it or just turn it on or off from your phone. It’s rated for 15 amps. They only cost around 14 bucks.
Fordracinjunkie is offline
post #29 of 33 Old 01-16-2019, 04:56 PM
JustinOOO9's Avatar
Quoted: 1679 Post(s)
Garage
Feedback Score: 3 reviews
I KEPT TRYING TO FIND THIS THREAD. I SAVCED THE ITEM TO MY AMAZON LIST AND WAS CURIOUS HOW MUCH YOU LIKED IT LOL. i'LL KEEP WAITING MAYBE?
SORRY FOR ALL CAPS. STUPID KEYBOARD ISSUES
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #30 of 33 Old 01-16-2019, 05:09 PM Thread Starter
Quoted: 172 Post(s)
I looked into the outlets as well. The ONLY thing that kept me from going that route was I'd be tied to that outlet only. Or, I could have bought 3 and put them in the three spaces I would be plugging the truck in. My driveway gets crazy with the wife's routine and the kid coming home from school. So I wanted to keep the option of using it no matter where I parked.
It has been working great using the outlets closest to the router. The farthest one was where I had the issue. It would turn on fine, and I could turn it off. The countdown clock was just getting hosed up. In the end, I am very happy with it. It has been snow tested. I had the truck at the end of the driveway last weekend and plugged it into the outlet on the porch. Haven't used it in the rain, but it is supposedly rated for wet locations as long as the outlets face down. My exterior outlets are weatherproof while in use. There is a plastic cover that encompasses the outlet while you jave stuff plugged in.
five0merc and JustinOOO9 like this.
2015 Oil Burner
