2020 Door sticker/Payload numbers - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2020+) General 6.7 Discussion
 15Likes
post #1 of 35 Old 12-22-2019, 06:21 AM Thread Starter
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 940 Post(s)
Feedback Score: 3 reviews
First up: 2020 F350 6.7L Crew Cab Long Bed SRW with Platinum trim. Not bad at 4,561lbs for a load rating.
ZMANN and Work Truck Fanatic like this.
Officially The Biggest Midget In The Game
HeavyAssault is online now
post #2 of 35 Old 12-22-2019, 06:30 AM Thread Starter
N.S.D.Q.
Quoted: 940 Post(s)
Next up: 2020 F350 6.7L Crew Cab Long Bed SRW with Lariat trim/Sport Package. Not bad with 4,513lbs load rating.
Work Truck Fanatic likes this.
post #3 of 35 Old 12-22-2019, 08:47 AM
cletusjermal's Avatar
Quoted: 411 Post(s)
Are they both SRW? Im assuming they are since they are GVWR of 12,400. That is pretty good if they are. The extra 1,000 lbs of payload will be nice.
HeavyAssault likes this.
2017 F350 6.7L 4x4 FX4 SRW CCSB Lariat Ultimate
Sold2002 F350 7.3 4x4 SRW CCLB. GTP38R, PIS 175/80 injectors, Sam Wyse Stage 2 Trans, 6.0 cooler, Banks Intercooler, 4" Turbo back Exhaust, PHP tuned TS 6 position chip, CNC 4 Line feed, HPOP and HPX Lines. International bellowed up pipes. AFE Stage 2 Intake w/ Dry filter. Banks exhaust brake and smart lock. Hutch/Harpoon mod, 910 Valve springs, Billet intake plenums. Firestone airbags. Trailready full guard front bumper. PIAA Driving and Fog lights. Micky Thompson Wheels.
cletusjermal is offline
post #4 of 35 Old 12-22-2019, 09:31 AM Thread Starter
N.S.D.Q.
Quoted: 940 Post(s)
Yes, both SRW trucks added on edit. I wanted to post these as I know people will be asking those questions. Some will want to see differences in trim levels/options...etc etc.
I'm surprised as to the numbers myself compared to the DRW showing 5,413 lbs payload. Not to mention the numbers above reflect a SRW curb weight of something around 7,900lbs. This is gaining a 500+lb (if not more) difference over some of the older trucks which helps.
post #5 of 35 Old 12-22-2019, 11:10 AM
SuperCrutyPS's Avatar
Quoted: 657 Post(s)
Garage
So..."Platinum" is a heavier metal. That would account for the 48lb difference!
- I'm sure the "P" version has some gizmos the "L/SP" doesn't have.
Those are good #s. My '01 isn't close. But I don't have a truck payment either.
ZMANN and hogbody like this.
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB |
5th Wheel |
Proud US Navy Veteran | '76-'80 -
- 'Gator Navy
SuperCrutyPS is offline
post #6 of 35 Old 12-22-2019, 02:19 PM Thread Starter
N.S.D.Q.
Quoted: 940 Post(s)
Those numbers are what is given as the payload capacity you should be able to carry for each truck. So the Platinum can carry more...albeit 48lbs.
I didn't go down the window sticker to do a "one-for-one" option comparison. On first glance the trucks were damn close to identical: Snow PLow, Aux Heat, 5th wheel prep, 4wd, etc etc etc
So it's not that big a difference between trim lines. I just wanted to post what I have been finding. I may find and post the F350 DRW trucks and F450 trucks just to see where the numbers fall out.
post #7 of 35 Old 12-22-2019, 02:47 PM Thread Starter
N.S.D.Q.
Quoted: 940 Post(s)
Next in line: 2020 F450 6.7L Crew Cab Long Bed DRW with King Ranch trim. Interesting to see 4,782lbs payload, but then again those are big hips. LOL
post #8 of 35 Old 12-22-2019, 02:59 PM
Spirit's Avatar
Quoted: 25 Post(s)
[QUOTE=HeavyAssault;16366335]Next in line: 2020 F450 6.7L Crew Cab Long Bed DRW with King Ranch trim. Interesting to see 4,782lbs payload, but then again those are big hips. LOL
In Spanish slang, the drw model is referred to as a petacona (big butt)...whatever the name, they sure cruise down the highway comfortably...
Spirit is offline
post #9 of 35 Old 12-22-2019, 03:20 PM
ZMANN's Avatar
Quoted: 4030 Post(s)
thats almost enough to haul ( within capacity ) a standard upscale slide in camper ( lance/arctic fox etc with maybe 1 slide
pretty good considering the past capacities you almost needed a 2 wd single cab dually ,,
6.0 flush pdf
ZMANN is offline
post #10 of 35 Old 12-22-2019, 03:20 PM
Fishsizzle's Avatar
Quoted: 153 Post(s)
Garage
Did I read that right? A DRW KR was only about 200lb more payload over they Platinum SRW?
So now CC F350 short bed is up if anyone see one.
2017 F250 CrewCab Short, leveled with 35/12.5/20 Toyo MT. Fuel 20x10
TOTALED: 2010 F-350 6.4 Crew-Short, Sinister Deletes, Coolant Filter. SCT with Tunes. CTS2 monitor, Mishi Rad, CFS Intercooler. Cold Side pipe, Down Pipe. 2.5 level, 295/65/20 Kenwood 9900 Apple Car Play
Fishsizzle is offline
