DPF % and OCR Screens - Help me understand - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 1Likes
post #1 of 13 Old 01-18-2020, 05:42 AM Thread Starter
Vet4jdc's Avatar
I'm dropping off my 2017 F250 SD at the Ford dealer on Monday for an oil change and state inspection. While it's in the shop and since I do a lot of short trip driving (7 miles to work), I am having them load the DPF percentage feature and the OCR so I can do manual regens in necessary.
My question is this, when they load these features, what will I see on the dash?
I know under the "truck info" screen I will see the DPF % screen.
Will I also see an on-screen option for the OCR? Or is the OCR option only coming up when the % is full?
In short, will I see two new screens or only one?
2017 F250 SD 4x4
Vet4jdc is online now
post #2 of 13 Old 01-18-2020, 06:33 AM
blackfords's Avatar
Quoted: 23 Post(s)
1sceen. You will only be able to Regen when it reaches 100%
blackfords is online now
post #3 of 13 Old 01-18-2020, 08:33 AM
Quoted: 16 Post(s)
It will regen on its own when it gets close to 100%. I dont think you can manually do it and why would you? Your gas mileage goes south when this happens. Just watch it and let it do its thing.
2018 Ford F-350 Lariat CC SB 4X4 6.7L Powerstroke Diesel
Jim Smyth is offline
post #4 of 13 Old 01-18-2020, 10:01 AM
blackfords's Avatar
Quoted: 23 Post(s)
It will Regen on its own. If he is doing short trips it will not complete unless he drives it. If it gets to 100% percent he will be able to do it manually
The Following 2 Users Say Thank You to blackfords For This Useful Post:
Vet4jdc (01-18-2020)
post #5 of 13 Old 01-18-2020, 11:14 AM
Quoted: 30 Post(s)
You should also have a check box in settings to turn off auto regen.
I also make a lot of short trips and keep the auto regen turned off. This keeps the truck from starting regens that I know won't finish. I turn auto regen back on when the filter is full and I'm going to be driving enough to complete the cleaning. Every time I start the truck I have to click ok to acknowledge the auto regen feature is off. I have never done a stationary regen and don't plan to as I see it as a complete waste of fuel. I'd rather the lion's share of exhaust heat come from moving me down the road and only enough additional fuel to clean the DPF be added.
Work Truck Fanatic likes this.
2019 Silver Spruce Lariat CCLB SRW F-350 FX4
Sport45 is offline
The Following 2 Users Say Thank You to Sport45 For This Useful Post:
post #6 of 13 Old 01-18-2020, 01:59 PM Thread Starter
Vet4jdc's Avatar
Correct, I never know on short trips if its going to regen and then not finish. At least this way I can monitor it and know when its close and drive it if needed. Thanks blackfords, I just needed to know what to expect and that the dealer installs the DPF % correctly.
2017 F250 SD 4x4
post #7 of 13 Old 01-18-2020, 02:45 PM
blackfords's Avatar
Quoted: 23 Post(s)
I don't have a checkbox to turn auto Regen off. Maybe I'm missing it.
post #8 of 13 Old 01-23-2020, 09:48 AM
cletusjermal's Avatar
Quoted: 411 Post(s)
Also the OCR only shows up when it is in park. It won't show up at 100% if you are driving. I use the OCR if the filter is at 100% and i don't have a highway trip planned that will complete a full regen. That way I don't drive it just to complete a regen and put the extra miles on it.
2017 F350 6.7L 4x4 FX4 SRW CCSB Lariat Ultimate
Sold2002 F350 7.3 4x4 SRW CCLB. GTP38R, PIS 175/80 injectors, Sam Wyse Stage 2 Trans, 6.0 cooler, Banks Intercooler, 4" Turbo back Exhaust, PHP tuned TS 6 position chip, CNC 4 Line feed, HPOP and HPX Lines. International bellowed up pipes. AFE Stage 2 Intake w/ Dry filter. Banks exhaust brake and smart lock. Hutch/Harpoon mod, 910 Valve springs, Billet intake plenums. Firestone airbags. Trailready full guard front bumper. PIAA Driving and Fog lights. Micky Thompson Wheels.
cletusjermal is offline
post #9 of 13 Old 01-25-2020, 07:40 AM
Quoted: 17 Post(s)
I want to get that screen loaded into my tuck but when I asked the dealer about getting it done I got a deer in the headlight look. He then asked, you can do that?
My ford history:
99 F350 7.3L CCLB 4X4 Superchips chip
05 6.blow F250 CCSB 4X4 Superchips tuner
02 7.3L F350 XCLB Dually
03 7.3L CCSB 4X4 Edge CTS
cknapp056.0 is offline
post #10 of 13 Old 01-25-2020, 01:49 PM
Quoted: 3 Post(s)
It's a quick fix with Forscan. It took me less than 10 minutes.
sandmandjs is offline
