FYI - Recalls (that I had done) - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 1Likes
post #1 of 12 Old 01-16-2020, 05:20 AM Thread Starter
Quoted: 337 Post(s)
Brought my 2017 to Ford yesterday for 3 recalls:
1) Engine block heater replacement (Field Service Action Number:19G01)
2) Unintended tailgate opening (Ford Recall number: 19S48)
3) Carpet shielding and insulation rework (Field Service Action Number:19S52)
#2 is new (December 2019). I didn't even know about it until the dealership told me when I went to schedule #1.
2017 F350 DRW King Ranch FX4
Blue Jeans w/Caribou Accent
No mods...yet. Enjoying stock and full warranty!
2004 F350 6.0 - Traded 2/4/17 (Pity the fool who bought it)
jd4010 is offline
post #2 of 12 Old 01-16-2020, 07:38 AM
Alberta Advantage's Avatar
Quoted: 86 Post(s)
There’s also Recalls for door latches freezing and day time running lights. My cousin couldn’t get into his truck the other day.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3 of 12 Old 01-16-2020, 07:55 AM Thread Starter
Quoted: 337 Post(s)
You are correct on the door latches but I didn't see the one on daytime running lights via the Ford Owner site. Will have to check into that.
Apparently the door latch thing isn't a recall but rather a TSB for those that may be in an area that could experience it. I opted not to worry about it since we don't freeze too often in NC.
jd4010 is offline
post #4 of 12 Old 01-16-2020, 07:59 AM
Quoted: 86 Post(s)
Could be a Canadian thing. I have all the recalls you mentioned in addition to door locks (recall in Canada) and DRL.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #5 of 12 Old 01-16-2020, 10:33 AM
Quoted: 377 Post(s)
Garage
I was in for door latch freezing ...this is only a recall that they will fix IF IT HAPPENS well guess what it happened to me. Door lock on drivers door froze Open yes Open ...so I drove my 80K truck around most of the morning holding the door closed LOL....parked it with the sun beating on that side for a few hours and it started locking again....
Had all these done you have listed on the same day I got the locks fixed 4 1/2 hours 2 guys
except #2 because they didn't have the parts....
So I have to go to Ford again for that
New 2019 F350 CCLB Platinum
Last Truck 2006 F350 CCLB KR
I'm out old man. I'm just a pecker-wood who lives in the woods with too many guns. Ya happy?"
BridgerMT is offline
post #6 of 12 Old 01-16-2020, 11:18 AM
G8orFord's Avatar
Quoted: 2604 Post(s)
Garage
My truck had already had the door latch freezing FSA done when I bought it. However, I still had to take it in because whoever did it did a sloppy job and it was causing an issue with the door locks.
I still have to get the block heater, tailgate and carpet insulation recalls done though.
I need to call and set that up and make sure with the service manager that they won't have a problem with my louder than normal exhaust.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is online now
post #7 of 12 Old 01-16-2020, 11:45 AM Thread Starter
Quoted: 337 Post(s)
An appointment is definitely recommended. I originally called my dealership the week of Christmas to get just the block heater done (they had already snipped the plug off) and the service adviser informed me about the tailgate. He had to order parts for the tailgate which took about 10 days to get and then he called and we setup a time.
jd4010 is offline
post #8 of 12 Old 01-16-2020, 05:02 PM
Quoted: 49 Post(s)
Door locks freezing is a field service action. Will only repair if the problem is present.
The only recall I have been notified of is the daytime running lights one. I have not received anything about the carpet fire, tailgate opening, block heater or anything else. 2018 F 350 Limited.
TeddyD is offline
post #9 of 12 Old 01-16-2020, 05:27 PM
G8orFord's Avatar
Garage
Your build date maybe exclude you from some of the recalls.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
post #10 of 12 Old 01-16-2020, 08:55 PM
Quoted: 23 Post(s)
I took mine in for scheduled service. They did the tailgate issue, the seat belt tensioner, and the freezing door locks. He told me the daytime running light issue is that on some builds the running lights may stay on with the brights on, and that exceeds legal forward wattage. I told him that wasn't a problem for me, so they didn't touch it. Oh yeah, they also replaced the steering damper, as I had death wobble last week.
nlvmike is offline
