PTO Provision Transmission - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
post #1 of 5 Old 12-06-2019, 07:14 AM Thread Starter
BigGreen06's Avatar
Quoted: 152 Post(s)
So I have the Live-drive PTO for my 19 F450, and i am wondering if i can hook a Hydraulic Winch up to it. Is this a possibility?
Work Truck: 2010 F350 KR Oxford aka 'Polar Xpress'
DD/Tow Rig: 2014 F350 KR aka 'Blue 343' - RIP
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
LineX
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen;
BigGreen06 is offline
post #2 of 5 Old 12-06-2019, 03:26 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 923 Post(s)
Feedback Score: 3 reviews
I think the issue would be finding the correct pump that fits the PTO output and is rated as such.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 5 Old 12-06-2019, 08:00 PM
Quoted: 30 Post(s)
It might be easier to plumb the winch into the power steering system. I believe Mike Marker winches are set up this way.
2019 Silver Spruce Lariat CCLB SRW F-350 FX4
Sport45 is offline
post #4 of 5 Old 12-07-2019, 09:43 AM Thread Starter
BigGreen06's Avatar
Quoted: 152 Post(s)
Yeah, that's the way MM is. I just figured a Hydro winch would be a good use of the system
LineX
post #5 of 5 Old 12-10-2019, 12:35 AM
Quoted: 53 Post(s)
To connect your PTO provision to the hydraulic winch you'd need a PTO and pump. (PTO would drive the pump, the pump would provide fluid power to your winch).
On our F550 w/ PTO provision, we have a Muncie PTO connected to the transmission PTO point, then a Muncie hydraulic pump connects to the PTO and has hydraulic fluid ports. In essence, we are running the PTO to provide power to the hydraulic pump, which provides hydraulic fluid power to our two hydraulic pumps on the rig. These pumps allow us to pump & dispense oils to our customers. We used the factory PTO pre-wiring to the factory upfitter switch so we can engage/disengage the PTO.
We used the below part numbers (not saying these are for your application, just using as reference for you).
PUMP: PH1 11 02ASRLM
PTO: FR6Q F1209 63QX
My Current Fords:
2018 F350 6.7L CCLB DRW Limited
2017 F550 6.7L CCLB DRW XL
fosterelli is offline
