fuel temp and second cooling system temp PIDS - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
post #1 of 3 Old 12-03-2019, 07:00 AM Thread Starter
scha0786's Avatar
Quoted: 100 Post(s)
I contacted Edge about pulling these PIDs from the ford computer and they won't or can't do it.
This would be so nice to be able to monitor fuel temp for us northern states to keep an eye on fuel gelling issues. Also the monitoring the secondary cooling system temperature is crucial I feel. Does the ford cluster even monitor or let you know if the water pump failed?
I really feel that ford or aftermarket needs to acknowledge this as a total separate system and provide a gauge or idiot light of some sort. I mean i did pay 50k for this pig, I demand gauges!
2019 F350 6.7 CCSB 4x4 XL with STX 3.55 elocker LED license plate lights Iconic OEM running boards coverking seat covers AVS bug shield Edge insight CS2
04 F250 6.0L (sold at 254k and rollin stock HG, HPOP, injectors)
scha0786 is offline
post #2 of 3 Old 12-03-2019, 08:43 AM
Alberta Advantage's Avatar
Quoted: 75 Post(s)
I picked up a FASS lift pump on Black Friday along with the heater disk so I don’t have to worry about a gell up situation. I also have a CTS2 I use for monitoring and will be getting the pressure gauge EAS expansion and there’s a bung in the FASS for it so hopefully, I can see if there’s high pressure, I can interpret that as a clogged filter be it sediment or gelled fuel. Edge does have a temperature probe expansion available. If these trucks did everything everyone wanted, none of us could afford them.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3 of 3 Old 12-04-2019, 04:00 AM Thread Starter
scha0786's Avatar
Quoted: 100 Post(s)
Ford has all the sensors installed. Edge needs to just pull them from the ECM.
scha0786 is offline
