Exhaust Brake Ambient Air Temperature - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
post #1 of 15 Old 11-27-2019, 11:58 AM Thread Starter
Alberta Advantage's Avatar
Quoted: 70 Post(s)
Does anyone know what the ambient air temperature is that disables the engagement/use of the engine brake feature?
Tried using it this morning and it was -21*C or about -6*F with windchill and it wouldn’t work. Let my truck sit in a heated shop for about 30 minutes and it worked no problem.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #2 of 15 Old 11-27-2019, 04:40 PM
7.3lf550's Avatar
Quoted: 90 Post(s)
Mine works all winter. Even below 0*F. Maybe it wont work until EOT/ECT at a certain temp?
03 7.3l 550, FRx, 6637 mod, 4 inch turbo back, ccv delete, aih delete, HPx, Riffraffs OCR, Turbo-pyro-boost-coolant EV2 gauges, Bullydog GT tuner.
03 X 6.0 175/30 warren sticks, Livewire TS w/ warren tunes, Blue spring mod, atlas 40 ficm, 270amp dc power alt
Originally Posted by Heavy_GD View Post
goats lives matter.
7.3lf550 is offline
post #3 of 15 Old 11-27-2019, 04:44 PM Thread Starter
Quoted: 70 Post(s)
I think it was just a fluke that it didn’t work today. EOT/ECT was 150/154 respectively. I even restarted my truck and it still wouldn’t engage until it sat for 30 minutes in the shop. No codes were thrown either.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #4 of 15 Old 11-27-2019, 04:54 PM
7.3lf550's Avatar
Quoted: 90 Post(s)
Tomorrow morning as soon as i start my truck i will see if it comes on and let you know.
This is in a 2019 f550.
goats lives matter.
7.3lf550 is offline
post #5 of 15 Old 11-27-2019, 05:12 PM
Quoted: 36 Post(s)
I found that when it was in the single digits, I wouldn’t turn the exhaust brake on until the cab was pretty warmed up. Otherwise the exhaust brake light would flash and not turn on. I think it was the relay in the dash being too cold because once the dash was warmed up some it would turn on fine.
73IH810 is offline
post #6 of 15 Old 11-28-2019, 11:38 AM Thread Starter
Quoted: 70 Post(s)
Not a fluke/one off. Wouldn’t work this morning either. Local dealership has a call into Hotline to find out the exact temperature that it becomes disabled. Guess I’ll find out in a couple days as they’re closed for Thanksgiving.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #7 of 15 Old 11-29-2019, 07:37 PM
7.3lf550's Avatar
Quoted: 90 Post(s)
I totally forgot to check yesterday morning, however i did this morning.
Ambient temp was 29 degrees. EOT/ECT 30 degrees
Started truck, waited 2-3 seconds for dash to clear, and hit the button. It came right on. Waited 30 seconds or so, headed down the road, and it was definitely working.
Maybe 30 degrees isnt cold enough
goats lives matter.
7.3lf550 is offline
post #8 of 15 Old 11-30-2019, 10:27 AM Thread Starter
Quoted: 70 Post(s)
I just went to the dealership as they have a 2018 Platinum F350 in their used lot that’s speced the same as mine. Grabbed a salesman and the keys, fired it up, and the exhaust brake turned on, no hesitation, no problem. If a used truck in a crappy economy that’s sat on the lot for weeks/months and hasn’t been moved isn’t the best test subject, I don’t know what is.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #9 of 15 Old 12-02-2019, 04:38 AM
scha0786's Avatar
Quoted: 100 Post(s)
do you guys put the exhaust brake to on or auto? I typically flip it to on when i'm heading down grade otherwise I leave it off.
2019 F350 6.7 CCSB 4x4 XL with STX 3.55 elocker LED license plate lights Iconic OEM running boards coverking seat covers AVS bug shield Edge insight CS2
04 F250 6.0L (sold at 254k and rollin stock HG, HPOP, injectors)
scha0786 is offline
post #10 of 15 Old 12-02-2019, 05:45 PM Thread Starter
Quoted: 70 Post(s)
I put my exhaust brake onto “on.” I’ve never put it in “auto.”
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
