4-5 shift - Page 2 - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
post #11 of 26 Old 11-27-2019, 11:31 AM
G8orFord's Avatar
Quoted: 2594 Post(s)
Garage
The 6R140 is a true 6 speed. 5th and 6th are both overdrive gears. If you push the "upshift" button on the shift lever it will light up the selected gear display and show the current gear. I'm running a delayed shift TCM tune and the 4-5 shift is at ~45 on light throttle, 5-6 is at ~55. The converter will lock in 3rd through 6th on my tune. Not sure where the stock tune locks at.
http://www.dieselhub.com/trans/6r140-torqshift.html
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #12 of 26 Old 11-27-2019, 11:57 AM
jman37's Avatar
Quoted: 394 Post(s)
Garage
Ford 6R140 TorqShift Transmission Specs & Ratios
This whole thread if F'ed lol. The 2nd guy who commented owns a 6.0, I don't think he realized he was in the 6.7 section, talking about his imaginary 6 speed. I commented because I saw his "back in a 6.0" post so I was informing him he does not have a 6 speed. Technically it "is," but it isn't.
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's - Sold
'17 Grand Cherokee SRT - Stock
'97 SVT Cobra - Few things
'88 Mustang LX - Built 306ci, built AOD, 4.10's - Sold
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is offline
post #13 of 26 Old 11-27-2019, 12:03 PM
Work Truck Fanatic's Avatar
Quoted: 29 Post(s)
I'm in 5th from 35-45 mph. >45mph I'm in 6th
2017 Ford F250 XL 4x4 SRW, White
Work Truck Fanatic is offline
post #14 of 26 Old 11-27-2019, 03:49 PM
G8orFord's Avatar
Garage
Yeah, I got that. Just sharing some info with the OP. Sorry if it seemed otherwise.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
G8orFord is offline
post #15 of 26 Old 11-27-2019, 10:00 PM
shaneaustinanderson's Avatar
My bad,i was wrong. wasn't reading haha. I'll get back to my imaginary 6 speed lol.
Sent from my CLT-L04 using Tapatalk
shaneaustinanderson is offline
post #16 of 26 Old 11-28-2019, 03:08 AM Thread Starter
scha0786's Avatar
Quoted: 102 Post(s)
Lol I just re read everything, the second poster definitely has a 6.0 with a 5 speed.
Any who........
2019 F350 6.7 CCSB 4x4 XL with STX 3.55 elocker LED license plate lights Iconic OEM running boards coverking seat covers AVS bug shield Edge insight CS2
04 F250 6.0L (sold at 254k and rollin stock HG, HPOP, injectors)
scha0786 is offline
post #17 of 26 Old 11-28-2019, 10:06 AM
Quoted: 27 Post(s)
I just push the tow haul mode so it holds the gear a little longer. I got used to doing this in my RAM because it would shift way to early and then lug the motor to much.
Warboar is offline
post #18 of 26 Old 12-02-2019, 04:36 AM Thread Starter
scha0786's Avatar
Quoted: 102 Post(s)
stupid emissions, wrecks everything.
scha0786 is offline
post #19 of 26 Old 12-02-2019, 06:19 AM
G8orFord's Avatar
Garage
You can run emissions compliant PCM tunes along with a modified TCM tune or just run TCM tunes alone with the stock PCM tune.
The emissions compliant tunes are pretty good now. You still have to deal with the regens, DEF and the associated crap that come along with the SCR/DPF system, but you can enjoy a bump in performance too.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
G8orFord is offline
post #20 of 26 Old 12-02-2019, 06:49 AM Thread Starter
scha0786's Avatar
Quoted: 102 Post(s)
from ford?
scha0786 is offline
