Excessive Battery Terminal Corrosion - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 26Likes
post #1 of 43 Old 11-23-2019, 08:25 AM Thread Starter
Quoted: 10 Post(s)
Checking my truck before making an 8-hr trip (each way) and I noticed the worst corrosion I've ever seen.
2017 XLT with 20k miles.
Should I not be driving it? Do you think the dealer will replace the cable under warranty? How about the battery?
Thoughts on causes?
Before cleaning:
After quick cleaning:
swavescatter is offline
post #2 of 43 Old 11-23-2019, 08:46 AM
Alberta Advantage's Avatar
Quoted: 69 Post(s)
I too have the same corrosion on my posts but it isn’t nearly as bad as yours. Ford will come back and ask if you’ve ever had your batteries serviced/cleaned. This is not part of any dealership scheduled service, it’s an add-on. Maybe your dealership is better than mine, but warranty would not cover replacing mine for the reason above.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3 of 43 Old 11-23-2019, 08:58 AM Thread Starter
Quoted: 10 Post(s)
Wow. I guess I'll have to ask them. The passenger side battery is perfect.
post #4 of 43 Old 11-23-2019, 10:27 AM
Quoted: 8 Post(s)
Same here - 2016
Only happens on the driver's side batt. And, not as bad as your pics.
HeavyAssault likes this.
Phil S is offline
post #5 of 43 Old 11-23-2019, 11:30 AM
ZMANN's Avatar
Quoted: 3999 Post(s)
get some AGM and be done with corrosion
but i can tell by the condition of the top of the battery and the bracket that acid has been migrating all over so you may be " overfilling, bad battery boiling a cell, under filled,
you should really clean up that area and typically a coating of grease on the terminal and connector will keep oxygen and acid away preventing corrosion
also look for a crack at the terminal / housing area
6.0 flush pdf
ZMANN is offline
post #6 of 43 Old 11-23-2019, 12:36 PM
SuperCrutyPS's Avatar
Quoted: 640 Post(s)
Garage
Use some baking soda mixed in water to help get the corrosion off. Get something like this:
It keeps the corrosion in check.
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB |
5th Wheel |
Proud US Navy Veteran | '76-'80 -
- 'Gator Navy
SuperCrutyPS is offline
post #7 of 43 Old 11-23-2019, 12:46 PM Thread Starter
Quoted: 10 Post(s)
I'll see what the dealer says. This is the factory battery - Iíve never messed with it at all. Guess I should have but didnít notice it until now. I do Oil changes and fill the windshield washer reservoir so Iím in that area. This seems to have popped up out of nowhere...
ZMANN likes this.
post #8 of 43 Old 11-23-2019, 01:21 PM
Navy LDO's Avatar
Garage
I have the same exact problem (drivers side POS terminal). I am having the dealer replace the clamp and battery (both not covered by warranty). Will have to pay more attention when I am under the hood. May as well check it every few weeks when I wash the truck anyway! I bought some protectant to apply and keep it near the car wash stuff to remember.
Navy LDO is offline
post #9 of 43 Old 11-23-2019, 01:45 PM
ZMANN's Avatar
Personally I have had better luck with just about any type of grease over the spray on terminal protectants ( used to service some golf carts )
I sure do like my AGM batteries and the 0 mainatance but I still have a lot of lead acids
i try to keep the tops dry ( non conductive) and heavy grease on the + terminal
6.0 flush pdf
ZMANN is offline
post #10 of 43 Old 11-23-2019, 02:39 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 906 Post(s)
Feedback Score: 3 reviews
I can't believe this is still going on. Seems the past issues were related to the batteries cracking at the posts. Maybe this is a charging issue?? Causing the wet solution to "boil" and out gas to the posts??
Officially The Biggest Midget In The Game
HeavyAssault is offline
