Cab lights not working after DRL update @ dealership - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
post #1 of 5 Old 11-22-2019, 05:04 PM Thread Starter
usmcknight69's Avatar
Quoted: 4 Post(s)
So my F350 did not come from the factory with cab lights. I had Ford install them (Recon lights) after the fact. I brought my truck in today because a TPMS sensor failed and they replaced it. They told me after that there was a recall/update reference the Daytime Running Lights. Long story short. I noticed shortly after the update that the cab lights are not working at all. I brought it back to the dealer and they looked at it and said they may need my truck for a few days to figure it out. Any ideas?
***MOLON LABE***
2019 F350 Platinum SRW
SOLD
2005 F250 SCREW LARIAT 6.0L
ARP STUDS, GASKETS, SCT CUSTOM, AFE STAGE II
10" LIFT, 38X14X24 KUMHO MUDDERS
MKW WHEELS, AMP RESEARCH STEPS
4:56 F/R GEARS, 5% TINT, CLAYMORE HITCH
PHANTOM II VOLTMETER, BOOST, EGT
TRANS TEMP, 2 12" KICKER COMP SUBS,
PIONEER AVIC Z130, RECON TAILS, 3RD BRAKE &
CAB LEDS, HID 6000K HEADLIGHTS & FOGS
UPFITTERS, EXTANG REVOLUTION LO PRO, MBRP DUALS
W/O CATS
usmcknight69 is offline
post #2 of 5 Old 11-22-2019, 05:38 PM
Alberta Advantage's Avatar
Quoted: 64 Post(s)
Cab lights won’t come on when day time running lights are on. They should only come on when the headlights are on.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3 of 5 Old 11-22-2019, 05:54 PM
Quoted: 40 Post(s)
The DRL update is to make the C lights dimmer when the headlights are on. I assume since the DRLs are now dimmer when the headlights are on, your cab lights aren’t getting enough power to turn on. I assume they tied the cab lights into the DRLs
TeddyD is offline
post #4 of 5 Old 11-27-2019, 02:56 PM Thread Starter
Quoted: 4 Post(s)
Originally Posted by TeddyD View Post
The DRL update is to make the C lights dimmer when the headlights are on. I assume since the DRLs are now dimmer when the headlights are on, your cab lights arenít getting enough power to turn on. I assume they tied the cab lights into the DRLs
Yes. They wired the cab lights to come on when I turn on the daytime running lights.
***MOLON LABE***
SOLD
W/O CATS
post #5 of 5 Old 11-27-2019, 02:57 PM Thread Starter
Quoted: 4 Post(s)
Originally Posted by Alberta Advantage View Post
Cab lights wonít come on when day time running lights are on. They should only come on when the headlights are on.
Normally, that would be correct. But when they installed the cab lights, they wired them to the drl so they came on when I turned the drl on.
***MOLON LABE***
SOLD
W/O CATS
