P0625 codes - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
post #1 of 3 Old 11-21-2019, 08:56 AM Thread Starter
CB406_6.0's Avatar
Quoted: 4 Post(s)
Garage
P0625 codes
My dad has a 2019 6.7 and the other day a pack rat got into the engine bay. He must have got caught between the belt and pulley on start up cause it threw a the belt and split him in half. Re routed the belt and check pulleys to make sure they are good. Everything seems fine. No loose/bad wire I can see. Alternators are good. Batteries aren’t loose but it is throwing codes P0625 and P163C both are generator circuit codes. Any help on what it could be? Also can’t find any fuses bad.
06 6.0 F350 Powerstroke CCLB
5" lift w/35x13.5s, 20x12 Fuel Octanes
Bulletproofed, BD Manifolds and Up-Pipes, KC Stage 2 turbo, 4" turbo back exhaust
SCT X4,
All upgraded lights w/ LEDs
CB406_6.0 is offline
post #2 of 3 Old 11-21-2019, 10:04 AM
Quoted: 36 Post(s)
My guess would be that since it was starting and ran with the belt off, the computer saw no output from the alternator and that’s where the CEL is coming from. I would recommend getting those two codes cleared and then see if they pop back up after running it again. If you put a meter to the batteries can you see a higher voltage to verify the alternator is working?
73IH810 is offline
post #3 of 3 Old 11-21-2019, 10:23 PM
Quoted: 53 Post(s)
Ditto...reset the codes (if you don't have the tool you can pick one up dirt cheap)...then address them if they reappear.
My Current Fords:
2018 F350 6.7L CCLB DRW Limited
2017 F550 6.7L CCLB DRW XL
fosterelli is offline
