Changed filters today - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 22Likes
post #1 of 30 Old 11-11-2019, 04:26 PM Thread Starter
Quoted: 8 Post(s)
I changed the engine oil, oil filter, and both fuel filters on my 2019 today. With only 15 K miles on the odometer, it was my first fuel filter change and 3rd oil change on this truck. I was amazed at how clean the frame rail fuel filter appeared to be. Of all the diesel engines I have maintained over the years both personal, farm, and company equipment, I have never observed a filter medium with no visible dirt, crud, or discoloration. The frame rail filter looked as clean as the new one, only wet.
It sure makes me feel good about the new local fuel station where I have bought 98% of the fuel for this truck. I will continue to purchase all my diesel from this business unless I am traveling.
If the filter looks the same after the next change, I am thinking of just changing fuel filters every 20 K miles.
I cycled the key 5 times to purge the system and the truck started without hesitation on the first attempt.
And on a side note, I do not get the ticking or type writer sound after an oil change with this '19 which is a big deal for me. I had a '15 and a '17 that did not develop a ticking after oil changes but I had a '13 that sounded horrible for 1500 miles after every oil change. The '13 had several issues though so the ticking was one of the more minor problems it had.
Sent from my iPad using Tapatalk
HeavyAssault likes this.
highmileage is offline
post #2 of 30 Old 11-12-2019, 01:44 PM
scha0786's Avatar
Quoted: 97 Post(s)
what kind of oil and filter did you go with?
Also, do you have to pre fill the oil filter because it is so big? I've got 2k on mine and looking to do the oil change in the next week or two
I bought motorcraft filters but still on the fence with valvoline premium blue extreme full syn 5w40 or rotella full syn
2019 F350 6.7 CCSB 4x4 XL with STX 3.55 elocker LED license plate lights Iconic OEM running boards coverking seat covers AVS bug shield Edge insight CS2
04 F250 6.0L (sold at 254k and rollin stock HG, HPOP, injectors)
scha0786 is offline
post #3 of 30 Old 11-12-2019, 02:10 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 904 Post(s)
Feedback Score: 3 reviews
Pre-filling the oil filter is a point of discussion. Some will say "must", some say "can". Do what you wish, the 13 qts oil added includes the "dry oil filter". So pre-fill the filter as you want but don't exceed an oil change of 13 qts total.
JustinOOO9 likes this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #4 of 30 Old 11-12-2019, 03:46 PM Thread Starter
Quoted: 8 Post(s)
I always use the Ford Motorcraft filter and T6 Rotella 5w40. Probably doesn't matter but I always fill the filters if they install vertically and will hold oil.
post #5 of 30 Old 11-12-2019, 06:54 PM
Quoted: 53 Post(s)
Same here.
My Current Fords:
2018 F350 6.7L CCLB DRW Limited
2017 F550 6.7L CCLB DRW XL
fosterelli is offline
post #6 of 30 Old 11-13-2019, 02:59 AM
scha0786's Avatar
Quoted: 97 Post(s)
Ok cool. I’ll probably pre fill the oil filter because I can. Thanks for the tips!!!!!!
scha0786 is offline
post #7 of 30 Old 11-13-2019, 07:35 AM
18M_RWR's Avatar
Quoted: 37 Post(s)
Pre-filling the oil filter when doing oil changes helps to eliminate/reduce the 'dry pump' time the oil pump is filling the filter with oil and therefore not pumping any oil thru the engine. Also why most oil filters have a no drain back feature to them.
I always pre-fill every oil filter. I let the vertical hanging filters soak a bit and usually takes 2-3 top offs to get a 1Qt filter full. Horizontal filters I fill & top off once so there is at least some oil in them and typically not much will run out unless your slow to get it on.
μολὼν λαβέ | si vis pa∑​cem, pa∑​ra bel∑​lum
2016 F350 Lariat 6.7L CCLB DRW 4WD 4.30LS
14000#GVWR Pkg, HiCap-TowPkg, PlowPkg-ExtraHD Alt, WideTrack frt axle, Max frt springs
Sinister ColdSide Charge Pipe, OBDLinkMX+ MonitorApp on Fire7 tablet
18M_RWR is offline
post #8 of 30 Old 11-13-2019, 09:57 AM
scha0786's Avatar
Quoted: 97 Post(s)
Interesting points, thanks!!!
scha0786 is offline
post #9 of 30 Old 11-14-2019, 07:02 PM
Quoted: 6 Post(s)
I typically use the box the filter is packaged in, to support the filter while filling it up as 18M outlined, since it takes a few mins for the media to soak in the oil and top off.
- Will
2006 F350 CC SB - 130k to 207k "Sold"
2017 F350 CC LB - All Stock / Nitto Terra Grappler G2
SDER1 is offline
post #10 of 30 Old 11-14-2019, 08:12 PM
Quoted: 30 Post(s)
I donít pre-fill oil filters mainly because Iím lazy and really donít see a benefit. One thing to consider when pre-filling is that whatever oil you dump in through the threaded hole is entering the engine unfiltered. (Normal flow is outside-in on these.) And no, oil is not finely filtered before it is bottled.
I put 230k miles on my Ď91 F-150, 185k on my Ď00 F-250, have 140k on our Trailblazer and 110k on our Edge to name a few of the higher mileage vehicles I familiar with. None have had any lubrication related engine problems.
2019 Silver Spruce Lariat CCLB SRW F-350 FX4
Sport45 is offline
