Engine light & bad def fluid - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
post #1 of 7 Old 10-16-2019, 05:23 PM Thread Starter
SUPDAV's Avatar
2019 f250 6.7 13,000 mi. Driving home from long trip pulling a trailer, the engine light comes on. Take it to a dealer and apparently the problem is bad def fluid. Put some in from the dealer and mechanic cleared the issue through the obd port. Has anyone come across this before? Seems fine now.
SUPDAV is offline
post #2 of 7 Old 10-16-2019, 11:27 PM
Work Truck Fanatic's Avatar
Quoted: 13 Post(s)
Any idea what the diagnostic code was? I had Code: P203B - Reductant Level Sensor A Circuit Range/Performance and when I refilled the DEF tank the code went away but came back later. It ended up being. the DEF tank heater.
2017 Ford F250 XL 4x4 SRW, White
Work Truck Fanatic is online now
post #3 of 7 Old 10-17-2019, 03:05 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 839 Post(s)
Feedback Score: 3 reviews
Did you use pump DEF or from a jug??
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #4 of 7 Old 10-17-2019, 08:31 AM
Rocweiller's Avatar
Quoted: 70 Post(s)
What’s better? I haven’t used the pump def this far. Only have filled the def twice with peaks.
2008 F250 XLT SBCC grey flake, 33x12.50 Toyo m/t's on 18 inch mammoth wheels. Rhino lined go rhino nerf bars. S&B cai,Spartan tuned and straight piped. Fake *** chrome grille removed and a matching colored grille put in place.
Rocweiller is offline
post #5 of 7 Old 10-17-2019, 08:52 AM
jman37's Avatar
Quoted: 360 Post(s)
Garage
It's all the same stuff. The pump DEF, depending where you go, would have a higher turn around more than likely if you go to a truck stop, thus probably always being fresh. Jug DEF could be sitting for a little bit, then stores put them on clearance, so you could get an older jug depending where you go and how long it's been sitting.
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's - Sold
'17 Grand Cherokee SRT - Stock
'97 SVT Cobra - Few things
'88 Mustang LX - Built 306ci, built AOD, 4.10's - Sold
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is offline
post #6 of 7 Old 10-18-2019, 06:35 AM
Quoted: 331 Post(s)
I've only used BlueDef and when I go to buy it, I look for the freshest available. Here is how:
1. Find the code on the box (let's say GA202600054
2. GA = the plant that made the Blue Def
2. 20 = the year of manufactured + 1 year. So the batch was made in 2019
3. 260 = days remaining in the year manufactured. So 365 - 260 = 105. This jug was made on the 105th day of the year or April 15, 2019
4. 0054 = the batch code
2017 F350 DRW King Ranch FX4
Blue Jeans w/Caribou Accent
No mods...yet. Enjoying stock and full warranty!
2004 F350 6.0 - Traded 2/4/17 (Pity the fool who bought it)
jd4010 is offline
post #7 of 7 Old 10-18-2019, 01:16 PM
N.S.D.Q.
Quoted: 839 Post(s)
Originally Posted by Rocweiller View Post
Whatís better? I havenít used the pump def this far. Only have filled the def twice with peaks.
Just asking. Not sure if one would be better than the other. I can say jugged DEF that has sat in my garage for two years still kills weeds pretty f-n good.
