no tranny pan drain plug!!! - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 3Likes
post #1 of 19 Old 08-16-2019, 11:03 AM Thread Starter
scha0786's Avatar
Quoted: 76 Post(s)
WTF, my new 2019 6.7 has no drain plug for the tranny. It has a spot that seems to accept a drain plug if drilled and tapped.
Called my friendly local Autonation Ford Parts and the 2019 tranny pan part # links to the 2011 tranny pan which had a plug integrated. They are on back order and my name is now on the list along with 3 other people.
scha0786 is offline
post #2 of 19 Old 08-18-2019, 10:21 PM
Quoted: 53 Post(s)
Is that out of pocket or are they replacing them on Fords dime?
84flatbed is offline
post #3 of 19 Old 08-20-2019, 06:16 AM
Quoted: 331 Post(s)
Here is a thread that may provide you additional info. No drain plugs are common post 7/17 builds.
https://www.powerstroke.org/forum/ge...rain-plug.html
jd4010 is offline
post #4 of 19 Old 08-20-2019, 06:33 AM
ZMANN's Avatar
Quoted: 3897 Post(s)
you know the answer you just can't handle the truth
lol j/k
jd4010 likes this.
6.0 flush pdf
ZMANN is offline
post #5 of 19 Old 08-20-2019, 07:00 AM
Coops361's Avatar
Quoted: 5 Post(s)
I’m very happy mine was built on 06/17 then! I noticed I had a drain plug but others were saying they didn’t.
Coops361 is offline
post #6 of 19 Old 08-20-2019, 07:12 AM
Quoted: 53 Post(s)
lol j/k
Haha, gotcha, I wasn't sure if it was a mistake on Fords part. Trying to increase book time on a fluid change, or make it less appealing to the DIY guy?
ZMANN likes this.
post #7 of 19 Old 08-20-2019, 09:36 AM
ZMANN's Avatar
6.0 flush pdf
ZMANN is offline
post #8 of 19 Old 08-20-2019, 09:38 AM
ZMANN's Avatar
not that i would put it halfway up the side of the pan like that clown LOL
but u could use a add on kit and put it where the mark is on the pan where the plug should be like was mentioned
6.0 flush pdf
ZMANN is offline
post #9 of 19 Old 08-23-2019, 05:00 AM Thread Starter
scha0786's Avatar
Quoted: 76 Post(s)
the new pan with drain plug is only like $35
they are on back order though
scha0786 is offline
post #10 of 19 Old 08-23-2019, 05:41 AM
Brrrrrrr......cccccold
Quoted: 394 Post(s)
This guy IS a clown......
I hope he left all the shavings in his pan......
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
zsargent is offline
