no tranny pan drain plug!!! - Page 2 - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 3Likes
post #11 of 20 Old 08-23-2019, 07:00 AM
ZMANN's Avatar
Quoted: 4014 Post(s)
he will never drain them out since he put it half-way up the side of the pan
but the reference was for the product not the "clown activities " lol
6.0 flush pdf
ZMANN is offline
post #12 of 20 Old 08-23-2019, 09:23 PM
It is What IT is
Quoted: 436 Post(s)
yeh I get it....But what a Clown...
ZMANN likes this.
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
zsargent is offline
post #13 of 20 Old 08-24-2019, 08:45 PM
Quoted: 30 Post(s)
Originally Posted by scha0786 View Post
the new pan with drain plug is only like $35
they are on back order though
And how much for the perfectly good transmission fluid you waste to put the $35 pan on? Personally, Iíll wait until the fluid needs changing. Then Iíll consider whether I want to replace or modify the pan. Iíll probavl just let the dealer change the fluid though since it is only a once every 6 or 7 year event for me.
2019 Silver Spruce Lariat CCLB SRW F-350 FX4
Sport45 is offline
post #14 of 20 Old 08-24-2019, 10:04 PM
"draining" a Super Duty Transmission is like. welll. PI$$ing into the wind. (only wor$e)
Learn your truck and transmission, Find the PROPER FLUSH. (read: entire torque converter and cooler) procedure (and, no, HOT FLUSH isn't (always) a good solution.
Also, ANY "drain". (or FLUSH) without changing the in-pan transmission FILTER is absolutely STUPID!
so: result: No PAN DRAIN needed.
sevanson is offline
post #15 of 20 Old 08-24-2019, 10:06 PM
Or, be satisfied with no proper filtration and only 45-65% of the fluid changed
sevanson is offline
post #16 of 20 Old 08-25-2019, 04:55 AM Thread Starter
scha0786's Avatar
Quoted: 101 Post(s)
Two schools of thought here. I’m in the school that fluid drain every 30k is better than waiting till 150k when your tranny starts shifting weird.
Have you ever looked in a tranny flush machine? Also, when people start having shift issues what’s the first thing they do??? I bet it’s go to dealer to get a flush. Do you think the tech on Saturday takes the time to clean all the small fine metal shavings in the tranny machine?
Like I said, two schools of thought. Me I’ll do fluid drains every 30k and fluid and filter every 60k.
2019 F350 6.7 CCSB 4x4 XL with STX 3.55 elocker LED license plate lights Iconic OEM running boards coverking seat covers AVS bug shield Edge insight CS2
04 F250 6.0L (sold at 254k and rollin stock HG, HPOP, injectors)
scha0786 is offline
post #17 of 20 Old 08-25-2019, 06:45 AM
EastBay580's Avatar
Quoted: 35 Post(s)
I have never flushed a transmission, and will not. That is just me, saw too many issues when I was rebuilding transmissions when I was younger. I will pull the pan change the filter and add clean fluid. Then I pop off trans cooler line and start the vehicle and let the trans pump do it thing. I do that 2 or three times and and good to go. Fluid changes will rarely fix a problem if one is there and more times than not can make things worse. Just my opinion
Sent from my iPhone using Tapatalk
EastBay580 is offline
post #18 of 20 Old 08-25-2019, 08:39 AM
ZMANN's Avatar
that does not work with a lot of modern transmissions ( starting in 2003 for the Ford ) unless you want to remove a lot more fluid to reduce the mix ratio.
but regardless and say it did work . please explain how the Fords heated flush procedure is different than the old school method of replacing fluid as it comes out of the transmission ?
the Ford flush heats the new fluid so the cooler circuit stays open and has full flow to the coolers , if you do not heat the fluid you get a small percentage of oil running thru the cooler and you will be mixing new coolant into old at a high rate in the pan instead of exchanging the coolant old for new as desired.
I am fine with the DIY guy dropping the pan and doing a few fill and drains if the old fluid is in good shape but for someone who does not DIY and wants to get the transmission serviced I would not scare them away from a proper heated fluid exchange
the most popular "theory" i have seen posted as to why to avoid a flush, is the new fluid and its active detergents/solvents will wash out the grit between the friction surfaces
and cause slippage , so with that theory in place if you neglected to do service intervals you better just leave it since a flush or a pan drop and fill will net the same result ..
.. I would not feel comfortable taking a truck like that on a road trip
6.0 flush pdf
ZMANN is offline
post #19 of 20 Old 08-25-2019, 05:36 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 609 Post(s)
Feedback Score: 11 reviews
You must be on those white claws I have been hearing about.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #20 of 20 Old 09-21-2019, 04:48 PM
Motor Head's Avatar
Quoted: 8 Post(s)
Ram does the same thing about not having a drain bolt. Hmmmm...... My f250 tranny is 10x better than my 68 tho!
Motor Head is offline
