oil life meter - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
post #1 of 10 Old 05-20-2019, 01:21 PM Thread Starter
Lightbulb oil life meter
Hello I just bought an 2018 F250 lariat diesel. It has a oil life reset but it does not have an oil life meter? Any ideas where it is located? Is it possible it does not have an oil life meter?
805KBarn is offline
post #2 of 10 Old 05-20-2019, 01:53 PM
00t444e's Avatar
Quoted: 537 Post(s)
Just change it every 5K or 7-8K if you use synthetic. I never trusted those oil life meters.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #3 of 10 Old 05-20-2019, 06:05 PM
Quoted: 23 Post(s)
Do you use the FordPass app? I can see my oil life % remaining there under vehicle details. I think it’s also on the DIC where you reset it, but that may have not been so on the 18’s.
2019 Silver Spruce Lariat CCLB SRW F-350 FX4
Sport45 is offline
post #4 of 10 Old 05-22-2019, 05:57 PM
Quoted: 16 Post(s)
FordPass on my phone works like crap. Wont stay connected. Seems its one thing after another with that app since its inception. Wish they could get there $hit together.
2018 Ford F-350 Lariat CC SB 4X4 6.7L Powerstroke Diesel
Jim Smyth is offline
post #5 of 10 Old 05-22-2019, 06:30 PM
MnTim's Avatar
Quoted: 28 Post(s)
The Ford app works great for me. I have not had any problems with it so far.
MnTim is offline
post #6 of 10 Old 05-23-2019, 02:56 AM
Quoted: 321 Post(s)
I like the Ford App as well. Just wish that the oil life remaining would be an option on the dash as it is via the app.
2017 F350 DRW King Ranch FX4
Blue Jeans w/Caribou Accent
No mods...yet. Enjoying stock and full warranty!
2004 F350 6.0 - Traded 2/4/17 (Pity the fool who bought it)
jd4010 is offline
post #7 of 10 Old 05-23-2019, 04:52 AM
Quoted: 21 Post(s)
I have the same year and truck as you and I can't get FordPass to work or stay connected either. It connects randomly, no rhyme or reason. Can't trust it to get the data when I need it and it shows 500-700 miles off on the app what my actual speedo shows.
cscoios is offline
post #8 of 10 Old 05-29-2019, 06:26 PM
Daglover72's Avatar
Quoted: 3 Post(s)
Go to advanced settings
Daglover72 is offline
post #9 of 10 Old 05-29-2019, 06:58 PM
Quoted: 27 Post(s)
FordPass is always a few hundred KMs behind for me too. Every time I open the app, I have to select my vehicle and then back out because it won’t show any info. I select it a second time and then it shows the info. Never works on the first time.
There is no oil life meter on these trucks. In the owners manual, it states something along the lines of a dash warning popping up at around 15% and then again at 5%. As far as I know, that’s the only oil life monitoring available to the driver.
I have to check on fordpass before I go up north to work because there is not oil change place around and I’m not changing my own oil outside in the bush at -30. (Northern Canada). I never surpass 13,000km (8400ish miles) between oil changes. On my previous Dodge models, max I did was 10,000km. I think at my 13,000 intervals, the oil life percentage was at 20% on the lowest one. I should state that I’m just about to only do my 3rd oil change.
TeddyD is offline
post #10 of 10 Old 05-30-2019, 03:50 AM
Quoted: 321 Post(s)
I see the comments about the accuracy of Ford Pass and I'll have to say.....mine updates very regularly. Provided it can connect to WiFi, it passes the info along well. So make sure you can routinely connect to WiFi and it should be reliable.
jd4010 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oil Life Monitor M109R General 6.7 Discussion (2017-2019) 18 12-03-2018 07:10 PM
oil life notification mooseman100 6.7 Electronics Discussion (2017-2019) 3 09-27-2018 08:54 AM
Long life oil filters jayhawk238 General 6.7 Discussion (2011-2016) 1 05-07-2018 05:43 AM
Hour Meter Idle Time number nondem General 6.7 Discussion (2011-2016) 7 11-13-2017 06:07 AM
dashlight bulbs trrun 99-03 7.3L Powerstroke Interior Discussion 23 04-23-2006 06:19 PM
